My problem is that I have acquired a 2-6-4 tank in 5 inch, part built. ±The 0-6-0 is clearly a speedy. but it has the additional wheels. The boiler is without a Swindon bonnet. And has no dome, but has a belpair boiler with safety poppet valves on the flat, just like an LMS. Loco.The regulator appears to be on the superheater input. It also has what appear to be Fairburn side tanks. So it is a bit of a Marriage.
I would like to finish this loco, but what should it be. Should I cut the extended frames a build it as a Speedy or add an addition bottom slide bar and make a Fairburn tank. I had hoped that I could find an existing design for a Fairburn so I am not going to get to lost in the translation.
All wise words would appreciated
