A Question for Quorn owners/builders
Home Forums Workshop Tools and Tooling A Question for Quorn owners/builders
  • #163065
    Gray62
      @gray62
      I need to make a replacement tilting bracket for my Quorn T&C grinder, I have a large lump of 6082 alloy that is the right size. Any thoughts on suitability, possibly with the addition of a bronze bearing for the rotating base shaft, other than that it;s going to be hogged out of a lump of steel.
      I know the casting for this part is only £18 but I hate buying when I can make from stock.
      cheers
      CB
      Thought I'd add, I'm using split cotters for clamping rather than the split and pinch method shown in the drawings/book.
      Edited By CoalBurner on 08/09/2014 17:53:38
      Gray62
        @gray62
        Tilting bracket
        #163085
        John Haine
          @johnhaine32865
          I think alloy would be perfectly fine, especially using split cotters. It would be lighter, and I'd have thought quite rigid enough for grinding forces.
