A question about motor
Home Forums Workshop Tools and Tooling A question about motor
  • #563036
    PipesandStuff
      @pipesandstuff
      Hello
      I have just bought a swedish clone of the South Bend 9 lathe and it came with the original 0.5hp 3 phase motor. I have the correct capacitor and runs ok, but will this ruin or burn out the motor? Should I just buy a single phase motor?
      PipesandStuff
        @pipesandstuff
        #563039
        Ian Parkin
          @ianparkin39383
          Or buy a vfd ?
          #563043
          noel shelley
            @noelshelley55608
            Hi Tonny, IF it runs ok using a capacitor for phase shift , keep an eye on the temperature when using it. So long as it does not get to hot you should be OK. If the motor does burn out you can always get a single phase motor, ,75hp or even 1 hp if there is room, there are plenty of secondhand ones about. Good luck Noel
            #563045
            larry phelan 1
              @larryphelan1
              If it runs OK, what,s the problem ?
              Let sleeping dogs lie.
              #563055
              John Haine
                @johnhaine32865
                If you are thinking of buying a single phase motor then just buy a VFD instead. Probably cheaper and better than a new motor.
                #563057
                PipesandStuff
                  @pipesandstuff
                  Yes I was thinking of buying a single phase motor. How reliable are these VFD? I dont have alot of trust in electronics and if it breaks down, I am not able to fix it.
                  #563065
                  Oldiron
                    @oldiron
                    Posted by Tonny Andre on 16/09/2021 18:25:05:
                    I bought some cheap VFD's and they have been fautless for several years. Dont forget the motor needs to be dual voltage ie 230/415 wired Delta to work properly on a VFD
                    regards
                    Edited By Oldiron on 16/09/2021 19:27:19
                    #563140
                    PipesandStuff
                      @pipesandstuff
                      Thanks chaps for the replys. Will give some thought on that VFD thing.
