I have built three of these fascinating machines, the first I did as a test piece for my CNC setup, I subsequently built another two for friends, although I did deviate from the original plans on all three, I actually made the main table from solid, and machined the back out to remove weight from one of the tables as an experiment, this made no noticeable difference, I also experimented with differing sizes of ball, I eventually settled on 12mm dia, one other thing I did alter was lowering the tip on the inside edge at the turn, if you look careful the ball lifts on each turn very slightly, at one time I had all three running in sink for over an hour, but only once, its was mesmerising watching them and listening to the ball clicks in exact time, the longest one has ran continuously is 4 days, with a clean table and ball they will keep time to about two minuets per day, but are better described as novelty clocks rather than time pieces, they do look good.
Never had problems with power, and did you clean and oil the spring??
Shaun
Ill put some pics im an album later if I get time!!
Pics added.
Edited By Involute Curve on 21/12/2014 19:53:35
