On
6 August 2024 at 09:45 Howi Said:
Peter –
That failed, I am afraid. The temporary pass-word it sent expired so rapidly I could not use it!
Repeating a wrong password too often might result only in my being blocked, or even possibly reported as an attacker.
Am I, or Amazon, or both, the victims of some sort of fraud attempt here?
Since I had never previously used Amazon it could not have had a so-called “account” on my address.
Then send another request to reset the password, this time look out for it and put in your new password, they don’t expire that quickly.
The reset reply should take no more than a few seconds, you usually don’t get a temp password but a link to put in your new password.
Youy can do as many password resets as you like.
Don’t make this any harder than it is.
something isn’t sounding right here???
I agree with Howi. If an amazon account has been set up with Nigel’s email address, then Nigel can reset the password. It’s important he does this because it will lock out the bad guy, if there is one, and allow Nigel to check the account details. If someone else’s address and other details are on the account, then Nigel can report it using Amazon’s system.
For obvious security reasons, new passwords expire if the requester doesn’t apply them quickly. Don’t ask for a new password and wander off! Wait for it to arrive and follow the instructions immediately.
A likely explanation for this misadventure is that Nigel set up an Amazon account in the past, and forgot. I’ve done the same myself!
Howi says ‘Don’t make this any harder than it is.’ I agree – when in Rome, do as the Romans do. Try not to second-guess the system, because it causes faulty decision making. For example the notion ‘Repeating a wrong password too often might result only in my being blocked, or even possibly reported as an attacker.‘ is wrong in this case:
- Nigel already is blocked in the sense that he can’t log in. He has nothing to lose.
- Given that Nigel is suspicious of the account, and so far has failed to alert Amazon, it is to his advantage to be reported as an attacker, as a way of waking up the Amazon security team.
Nigel’s desire to jump Amazon’s system by writing to HQ rather than doing what’s asked could cause another problem. His letter is wending it’s way through Amazon’s bureaucracy, and may eventually reach someone who kills the account. If in the meantime Nigel activates the account following Howi’s advice, he will be hoist with his own petard!
Nick’s advice has legs too, but I’d keep it in reserve. Having more than one account is liable to cause other confusions.
