Hullo Diane,
This engine was developed by E and G to power small fishing vessels. The idea was evidently to shorten the length of the engine in order to increase the fish hold length. Apparently it was very successful and was fitted to many vessels though whether that extended to beyond the fishing industry we are not sure.
Unfortunately despite a considerable fishing industry here in the area (Lowestoft/Gt. Yarmouth) there is very little information on it. I have emailed Anthony Mount via the editor in the hope his vast knowledge may be able to shed some light but not heard anything yet
The person who contacted me, now in his seventies, served his time with E and Gs but obviously well after these were produced. It is our intention if sufficient information can be gained that, with local interest in mind, a model will be made – though Phil is considering making something larger to power his small steam boat. It is hoped that shortly we can meet someone who, now 96!, remembers working on them.
So far we have collated four different images and the overall dimensions – they were made in three sizes apparently but the catalogue image we have only gives two the larger being 9 3/4 x 15 x 22 witha 16″ stroke, however RH Clark in his book Steam Engines of Suffolk gives the largest as 9 1/4 X 15 x 26 by 16″ stroke.
The valves are worked by a rocking lever moved by the link ie. the valve rods are isolated from the link and as you can see the link is at one end only. (The ‘front’ of the engine as stated previously refers to its position in the boat)
What makes this engine unusal is that the cranks are set at 180 degrees with the flywheel set between and evidentally acting as the central web – this at the moment is a big grey area as none of the images give any indication as to how the crankshaft was supported in the bedplate – incidentally the flywheel diameter is one of the few known dimensions we have – 2’6″ – but the width is unknown.
Phil is currently producing a set of basic layout drawings from which we hope to flesh out the design but at the moment we do not wish to compromise anything with our own ideas until we have exhausted all possiblities of available material.
This pic of the rear of the engine is from the catalogue and is, we believe, from a photograph taken in the workshop. It is the best of those we have so far
And this view – too dark to decipher much I’m afraid is in the workshop itself and is I think the very same engine from the front end.
I have put this on here rather than by PM just in case it rings any bells with anyone else. If you or others are interested in our progress as it develops we will be only too happy to share it.
Hope this is of further interest. Obviously we would like to hear of anything even remotely connected so if anyone thinks they may have something we’d be very pleased to hear from them
Regards – Ramon
Edited By Ramon Wilson on 04/01/2011 17:57:57
