Posted by Andrew Tinsley on 15/11/2017 11:18:19:
Believe me, firearms regulations in this country are very tight for people who have a firearms certificate. I would not want it any other way.
The real problem seems to lie with illegal gunsmiths. I know of one legal gunsmith, locally, who "bent" the law and got into hot water.
It isn't really too difficult to make firearms, most of us could do so if we had a mind to. Ammunition is another matter. That is difficult to come by unless you have an FAC. There does seem to be a bit of a loophole in that you can legally buy all the bits necessary to make ammunition, but as said above, it is illegal to hold the completed article. Maybe the law should be tightened up in this area. It would affect those who make their own ammunition, however, if the FAC regulations were applied to ammunition constituent parts then those that do produce their own ammunition would still be able to buy the component parts.
Full bore ammunition is expensive and considerable cost savings can ensue by making your own. more care can be taken and reproducibility can be as good as or better than commercial ammunition.
Andrew.
Obsolete calibres such as those in the article are a peculiar part of firearms licensing – they are legal under Section 58 of the Firearms Act 1968, if they are on the 'obsolete calibres' list supplied by the Home Office, to be held without a Firearms Certificate.
As far as ammunition is concerned, it is legal to acquire unprimed, or fired, cartridge cases.
Bullets, primers, or primed and unfired cartridge cases, most certainly ARE controlled, and it is not possible to buy these legally without a Firearms Certificate, worded appropriately.
Another peculiarity of licensing is that if you hold a pistol under S. 58, and legally hold ammunition for the same gun, you commit an offence if you then fire said ammunition from the gun – you can hold the gun as an antique, but if you want to fire the ammunition you hold through it, it has to be moved from Section 58 to Section 1 of the Act, and held as a live firing gun, rather than as an antique.
Section 58 also exempts from the requirement that you show good reason to possess said firearm, moving it to Section 1 reinstates that requirement.
I speak as a Firearms Certificate holder.
