Posted by charadam on 29/06/2017 21:58:54:
I volunteer with REMAP and was recently modifying a fully-adjustable bariatric bed.
The modification required drilling a couple of clearance holes for 10mm bolts in the 13mm trunnions for the bed actuators.
The holes had to be drilled with hand held tools as the bed is large and unwieldy.
The pilot holes at 5mm and 7mm went well using HSS bits.
When the 10.5 mm HSS drill was tried in the first hole it smeared and raised a large burr on the surface, as well as wandering off centre by a good 3mm.
Edited By charadam on 29/06/2017 22:03:13
If you'd gone straight from 5mm or better still 3mm to 10.5mm with low speed plenty of pressure and a bit of lube now and then it would probably have worked fine.
The odds are good that you hooped the flutes on the 10.5 and cooked the material at the same time, it's a common misconception that small steps up to the finished size are a good idea because that works most of the time with lots of easily machined materials.
