A few years ago.
A few years ago.
Home Forums The Tea Room A few years ago.
Viewing 25 posts - 1 through 25 (of 38 total)
  • #37239
    Bo’sun
      @bosun58570
      Where did they go?
      Bo’sun
        @bosun58570
        A few years ago we had the Stone Age, the Bronze Age and the Iron Age. What happened to the Copper and Tin Ages? Presumably they would have preceded the Bronze Age.
        Or maybe I just slept through that bit of the history lessons.
        #647650
        John Hinkley
          @johnhinkley26699
          I suppose the copper and tin ages preceded the bronze age since the latter is an alloy of the former two.
          Bazyle
            @bazyle
            Gold came first but tin and copper aren't a lot of use on their own. I think the first bronze was just a lucky combination of the mixed ore being found long before the constituents were understood. Because bronze can hold an edge and not corrode like copper it found a use so became prized and sought after.
            #647660
            Mike Poole
              @mikepoole82104
              Are we in the plastic age now?
              #647662
              Speedy Builder5
                @speedybuilder5
                We are in the chuck it away and buy another one age I think.
                #647663
                Martin Kyte
                  @martinkyte99762
                  I think it goes Stone, Bronze, Iron, Uranium, Hydrogen.
                  regards Martin
                  #647664
                  Juddy
                    @juddy
                    I think the present time is actually called the age of technology
                    #647668
                    Ady1
                      @ady1
                      Posted by Mike Poole on 06/06/2023 13:05:53:
                      Post of the week lol
                      Tragic but very true, they'll still be digging that stuff up in a thousand years
                      #647670
                      Juddy
                        @juddy
                        Posted by Ady1 on 06/06/2023 13:55:20:
                        same as the stone and bronze age things
                        #647671
                          I'm with Bazlye – the first bronze was just a lucky combination of the mixed ore, not the result of extracting Tin and Copper separately and then melting them together. And "Bronze Age" is archaeological short-hand for a period of time in which Copper based metal tools started to appear, but the alloys weren't necessarily what we mean by Bronze today.
                          The ancient Egyptians and other civilisations had Copper tools but they didn't make much difference to daily life. Bronze is noticed because a metal that could be made into weapons that held an edge and shaped into armour was a war-winner. We have an Iron Age for the same reason – it walloped Bronze for making tools and weapons and that too changed everything.
                          What went on in the Bronze Age is pretty murky – no written records. But we know a great deal about modern metallurgy because science was applied to it during the 19th Century and we can track how metal making moved from intelligent guesswork to deep understanding. Brass was a great mystery until the early 19th Century. Made by mixing Calamine with Copper Ore and heating carefully, but no-one knew what was in Calamine. Turned out to be Zinc, hard to pin down because it vaporises well below the melting point of Copper and disappears up the chimney! Brass making was a skilled trade, with the secret passed from father to son, until the chemists worked out what Brass actually contained and in what proportions. Now Brass is easy to make – no magic in it atr all.
                          Similar story with steel. The prototype Bessemer process of 1856 produced large quantities of good mild-steel very cheaply. But consternation when exactly the same process failed miserably when other steel-makers tried it! Chemical analysis revealed the problem was impurities: by chance Bessemer tested with an ore unusually low in Phosphorous and Sulphur, both of which do horrible things to steel. Fixed by extending the blast and adding flux to burn off everything apart from Iron, and then adding Carbon and Manganese back to get an accurately pure mild-steel. Not quite perfect – later it turned out that batches of Bessemer mild-steel were inferior due to small quantities of Nitrogen left behind by the air-blast used to burn off impurities. Modern blast furnaces fix this problem by blasting with Oxygen rather than Air.
                          We rarely refer to the 'Steel Age' though it is a thing. 'Steam Age' is more common. Other examples not necessarily material related: Dark Ages, Middle Ages, Age of Discovery, Age of Enlightenment, Axial Age, Plastic Age, Glass Age, Aluminium Age, Computer Age, Information Age etc.
                          All of these 'ages' are broad tags, I think, that capture the main thrust of a time period rather than describing it accurately.
                          Edited By SillyOldDuffer on 06/06/2023 14:11:22
                          #647677
                          John McNamara
                            @johnmcnamara74883
                            A few years ago…
                            I started writing essays with a fountain pen. Now I use a computer that even corrects my not so great spelling..
                            Seeking knowledge was at the Library. I can still remember trawling through the index cards only to find the book was on loan and I had to wait. Now I can get a general answer in a few minutes, empowering my research along the way.
                            There is so much to do! With this enhanced ability comes the responsibility to make all things a little better in some way to and improve the body of work that represents civilisation.
                            It is good to look back only to the extent it confirms a path to your future. To me living in the here and now in the knowledge age is wonderful.
                            #647681
                            jaCK Hobson
                              @jackhobson50760
                              I had to drill bronze for the first time last week – it surprised me how difficult it was.
                              #647684
                              Bo’sun
                                @bosun58570
                                Just think what it must have been like during the Bronze Age!
                                #647687
                                JA
                                  @ja
                                  Copper is not a lot of use on its own! Ask an electrical or electronics engineer. Still they did not exist before the Bronze Age.
                                  I have always thought we still live in the Iron Age but I agree with Dave on that one (having worked in a steel works).
                                  JA
                                  #647690
                                  Anonymous
                                    Posted by John Hinkley on 06/06/2023 11:39:57:
                                    Maybe copper and tin ages occurred together so they combined them into one age called the bronze age.
                                    wink
                                    Edited By Peter Greene 🇨🇦 on 06/06/2023 16:54:08
                                    #647691
                                    Roderick Jenkins
                                      @roderickjenkins93242
                                      Posted by SillyOldDuffer on 06/06/2023 14:09:55:
                                      The ancient Egyptians used arsenical copper tools . Whether the arsenic was in the natural ore or added is, as yet, unknown but the alloy does take an edge sufficient to chop up stones for pyramids.
                                      Rod
                                      #647695
                                      Georgineer
                                        @georgineer
                                        Posted by John McNamara on 06/06/2023 15:00:56:
                                        … I started writing essays with a fountain pen…
                                        Ah, you youngsters don't know you're born! I had to master the dip pen before I was allowed to use a fountain pen, dipping into the inkwell at the right side of the desk (deuced inconvenient for us left-handers) and flicking the bits of pencil shavings and mushed up blotch off the nib before writing. My first founter was a maroon Osmiroid 65, and it cost 5/6d. Well, it was a few years ago…
                                        #647714
                                        Mick B1
                                          @mickb1
                                          There was a lot of overlap between the ages. I think some individual's supposed to've had an iron pot in the Trojan war, which was certainly Bronze-, rather than Iron Age. Plus communication was sporadic and uncertain, and those with what passed for metalurgical knowledge would often have been disinclined to share it, so the Iron Age probably came to northern Europe later than the Mediterranean.
                                          Cornish tin was being traded to the Phoenicians in the late Bronze Age, and that argues that they had worked out how to make decent tin bronze of reasonably consistent quality. The variety of copper alloys we might call bronze today makes me wonder if maybe they had a more definitive idea of what they thought of as bronze than we do!
                                          Even the pre-Columbian Meso- and South American civilisation turned up occasional copper tools (not heard of any tin ones) but as SOD said, the metals weren't game-changing enough to be generally adopted or spark any assiduous development there.
                                          #647715
                                          Clive Hartland
                                            @clivehartland94829
                                            Who had their first Biro that leaked in the shirt pocket? Now they are everywhere.
                                            One story is about NASA who spent a lot of money to make a pen that would write in zero gravity. then the russkies used pencils! KISS, keep it simple stupid.
                                            Edited By Clive Hartland on 06/06/2023 21:39:00
                                            #647718
                                            Anonymous
                                              Graphite particles floating around a multi-multi million dollar space capsule was considered by NASA to be an unacceptable risk.
                                              On the early Biro front, when I was about ten I had one in my trouser pocket which leaked and turned my leg blue. Not knowing what had happened, I was terrified. Thank heaven for Mums! (Even if I did have to, mortifyingly, take my trousers off in front of her).
                                              Edited By Peter Greene 🇨🇦 on 06/06/2023 22:14:23
                                              #647719
                                              duncan webster 1
                                                @duncanwebster1
                                                Posted by Georgineer on 06/06/2023 17:29:33:
                                                I remember buying nibs from the shop on the way to primary school, and the ink monitor had to keep the inkwells topped up, can't remember whether we had to mix it from powder or came in a bottle. I still use a fountain pen for anything important that needs to be hand written, but a lot of modern forms are printed on paper which is more like blotting paper so the ink spreads out and is blurred.
                                                #647722
                                                Nigel Graham 2
                                                  @nigelgraham2
                                                  I regret my hand-writing was never good and is now terrible (possibly a touch of arthritis in the fingers) otherwise I would use a fountain-pen much more.
                                                  I don't recall using dip-pens at school, only fountain-pens like my Osmiroid (later, the cartridge type). Inkwells though, yes, filled from a bottle.
                                                  Ball-point pens – the original 'Biro' after their inventor – were appearing around my last year in Primary School, to the dismay of our teachers afraid these "pig's-grease" implements would spoil our hand-writing. They didn't spoil mine… just made it worse.
                                                  One thing that seems to have vanished within only a 20C few decades was established centuries ago by practical experience in the era of books having to be hand-copied: the slanted desk or its neat 19C equivalent, the portable writing-slope that can be stood on an ordinary table. The concept survives in the token little folding feet on lap-tops and keyboards, and of course in drawing-boards; but that slope was devised for a very good reason, only to be thrown away apparently for no good reason.
                                                  #647728
                                                  Chuck Taper
                                                    @chucktaper
                                                    The Chalcolithic (copper age) fits between the Neolithic and bronze ages age.
                                                    The Anthropocene is where we are at now.
                                                    The Holocene cover the lot.
                                                    FC
                                                    #647729
                                                    David George 1
                                                      @davidgeorge1
                                                      Being an ink monitor was an inspired elevated position at school only surpassed by the milk monitor position. I was looking forward to that position when our class was moved to a comprehensive establishment and we had to provide our own fountain pen and ink.
                                                      David
