There is a certain amount of confusion – sorry. I start with a few facts in clarification:
1. The existing field coils were duff, so needed rewinding anyway. Therefore 'Just fit a regulator' does not address the issue.
2. I am not (yet) trying to test whether it generates. I know it motors and I need it to motor in the other sense. Motoring does not rely on a small amount of residual magnetism, as the field coils are energised by the applied voltage. The residual magnetism is only relevant when I test it as a dynamo. And in any event, I have tried flashing and while I did pass current, it made no difference.
3. The reason we have a cut-out on a traditional dynamo circuit is to stop the dynamo, when the engine stops, trying to turn as a motor. It is trying to turn in the direction it normally runs, so I am trying to test my dynamo to see if it will motor – but it does so the wrong way round.
4. Swapping the brush connections won't help in this case as one of the brush holders is earthed, or, more accurately, only one holder is insulated from earth.
5. Swapping the field winding end to end is surely the same effect as swapping the brush connections? This is what I have done and it makes no difference – that is my problem.
6. The problem is not to do with positive or negative earth wiring. A good dynamo will motor in the right direction whichever system is applied (but doing this the 'wrong way round' is likely to set up the residual magnetism the wrong way for charging the 'right way round'[close parenthesis].
So, thanks, everyone for your helpful replies, but we're not there yet.
Regards, Tim
Edited By Tim Stevens on 11/05/2019 23:22:28
