Posted by Jens Eirik Skogstad on 11/06/2019 10:17:23:
I has Vernier on round rotating table, then I can create the dividing disc and attached on the rear spindle on the Boley watchmaker lathe. First I must check the indexing in the indexing head is correct in divisions in the correct angle/distance between each hole on the test disc. I can't be sure it's my fault under operation or fault with divisions in the indexing head.
Jens
I have previously described a simple and effective [albeit tedious] way of doing that check.
To avoid re-writing, I will try to find the previous post.
Please see my post of 10-March-2019, here:
https://www.model-engineer.co.uk/forums/postings.asp?th=141169
I used seven holes as an example, but the principle applies
Edited By Michael Gilligan on 11/06/2019 10:32:34
