Hi Stub.
Thanks, that is a useful info site.
You are right about it being a Monoperm super, I also have a couple of Decaperms, these were all really good reliable motors.
They were originally bought for use in an SLEC Tank, having decided that flying model aircraft was not working out for me, and ground level models might be less costly!
Two Decaperms drove the tracks through some modified Meccano gears, independent control / reversing was courtesy of PCB type resistance boards fitted on top of The RC servos.
The Monoperm took care of turret rotation (the pile gears were used to get the speed right), and the gun elevation was by a small servo in the turret fed via slip rings / brushes on the turret rotator shaft.
I recently dug the tank out during a major loft clearance, it is a bit battered and corroded, might have a go at restoring it, but with loads of conflicting demands on my time lately even using the workshop is proving really difficult.
Edited By V8Eng on 26/09/2013 21:03:01
