Before getting to grips on some more ally for the next IC project I thought perhaps I should spend a short while progressing this project a bit further. It began far too long ago to mention – actually it was about 1998
and thoughts are very much toward having it run at next years Forncett do.
It’s the Waller Table Engine as designed by Anthony Mount in EIM but scaled 1.333 to 1. The flywheel is just under 12″ diameter.
It’s all made from ‘scrap’ – well spare – material. The base and table from steel plate and the cylinder parts from cast iron. This is extremely tough iron coming from the bed plate of a fifty ton press – I can’t begin to imagine how many blows that has recieved over it’s life but it should be well stress relieved
The cylinder and steam chest were made separately and are held together by two 8BA cap head bolts and JB Weld which also does a good job of creating fillets for a cast look alike.
The flywheel is also a composite – what looks like holes in the rim are – but they are infact the bottoms of previously drilled and plugged holes. Originally it had a half round periphery but it was decided to turn this off to give the flat section. (That’s what the filled holes are in the sidefaces to hold it to a face plate) doing this exposed the bottoms of the plugged holes.
When the rim was set up originally to drill the holes for the spokes it unfortunately moved on its mandrel so the holes done had to be plugged and new ones drilled. As it will all be painted it should not be visible once finished.
The rim was milled initially from a flame cut mild steel blank on the new CNC machine on a Friday afternoon when all had gone home – that’s the real downside to retirement – no bloody perks!
There is a fair bit to do as yet but this week has at last seen the start on the working parts so perhaps as it grows you might like to see a bit more later.
Hope that’s of interest
Regards – Ramon
Edited By Ramon Wilson on 03/11/2011 23:22:36
