48 dp involute gear cutters
Home Forums Help and Assistance! (Offered or Wanted) 48 dp involute gear cutters
Viewing 14 posts - 1 through 14 (of 14 total)
  • #206957
    Adrian Keaney
      @adriankeaney12991
      Hello everyone.
      I having difficulty sourcing a reasonable priced set of involute gear cutters no.4,7,8
      14 1/2 degree 48DP .
      Any help on where to look or another alternative would be much appreciated.
      I had looked at making gear hobs but this is not the road I want to go down.
      Regards Adrian
      Adrian Keaney
        @adriankeaney12991
        #206974
          Adrian,
          The likelihood of finding commercial cutters at a modest price is remote.
          You may find this thread of interest.
          David Clark 13
            @davidclark13
            Try RDG on Ebay
            #206980
            Ajohnw
              @ajohnw51620
              You could get a set of 0.5 mod from here and recalc things as needed the cp is 0.0037" shorter than dp 48
              You may need to look on rdg's web site rather than ebay.
              John Rudd
                @johnrudd16576
                #206986
                  I stand happily corrected …
                  Subject to availbility; those prices look much more affordble than the [cycloidal] horological cutters.
                  P.S.  Adrian does want 14 1/2 deg. Pressure Angle
                  … so availability may well be a problem.
                  Edited By Michael Gilligan on 07/10/2015 17:46:50
                  #206988
                  Ajohnw
                    @ajohnw51620
                    You could also make your own. Michael posted a link that leads to links to the sums. There are several ways of making cutters with relief about on the web so that they can be resharpened. Much depends on what you are cutting really. Hardened and tempered silver steel or gauge plate isn't too bad on brass or even mild steel.
                    ianj
                      @ians
                      Adrian.
                      I've just had the same quest for gear cutters no.2 & 3 14 1/2 degree 48DP .. I tried Tracy tools with no luck but they suggested "Home and Workshop Machinery" of Sidcup who had them pre used at £15 each + VAT & postage..
                      Ian
                      #207009
                      John Rudd
                        @johnrudd16576
                        Posted by Michael Gilligan on 07/10/2015 17:43:00:
                        I stand happily corrected ..
                        Oops, sorry Michael,I missed the pa criteria…my apology to you..
                        #207020
                        Ady1
                          @ady1
                          To get the DP, just add 2 to the tooth count and divide by the outside diameter
                          of the gear. So, 42 divided by 3.49 is 12.
                          So we have a 40 tooth gear=42
                          42/x=48
                          x=42/48
                          x=0.875 inch for 40 teeth
                          Is this for a watch or something?
                          #207025
                            Posted by Ady1 on 08/10/2015 02:11:33:
                            Probably an "or something"
                            48 DP is a fairly common size on small-ish mechanisms.
                            Adrian Keaney
                              @adriankeaney12991
                              Thanks for all the help, I got in touch with Home and Workshop Machinery and they have two cutters at a very reasonable price.
                              The cutters are for the Tiny Inline 4 engine
                              Once again thanks for all the replies everyone.
                              Regards Adrian
                              #207072
                              Roderick Jenkins
                                @roderickjenkins93242
                                Adrian,
                                I'm glad you managed to get what you were after.
                                In general, if you are making all the gears then it will not matter if they are 14.5 degrees or 20 degrees PA provided they are all the same. 14.5 is effectively an old standard and it is only important to match them if you are making a gear to fit with existing ones: change gears for British lathes are a common need. 20 degree PA gear cutters are more readily available and it opens up the opportunity to find a near equivalent in metric Mod sizes which are usually much cheaper.
                                Rod
