I looked up what I did a few months ago on the CNC mill with a 3 flute carbide cutter in hot rolled steel cutting a 4mm wide slot 2.38mm deep. I ran at 5000rpm, 120mm/min feed, full width when roughing and 0.48mm deep per pass. Coming down to 1800rpm and going up to 4 flutes gives a feedrate of 57.6mm/min. Seems I was pussyfooting around. ![sad sad](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
I hate using small cutters on a manual mill. It's only too easy to momentarily overfeed and then ping!
Andrew
