22mm x 16g steel tube
Home Forums Materials 22mm x 16g steel tube
  • This topic has 20 replies, 12 voices, and was last updated 6 July 2018 at 08:26 by Michael Gilligan.
Viewing 21 posts - 1 through 21 (of 21 total)
  • #358441
    mick70
      @mick70
      anyone know a supplier?
      tried local places but what they list 22mm is actually 7/8 now i know 0.2mm ish
      shouldn't matter but it does as for some custom length goose necks on bikes i'm building.
      if still had lathe set up would have gone for 14g and skimmed down but not an option.
      only other option is go for 14g and sand length using flap disc on grinder and marker pen.
      done it before and got good results but if idea works will need to make 50.
      mick70
        @mick70
        #358443
          Is 22mm plumbing pipe going to be too thin a wall?
          #358448
          mick70
            @mick70
            might be bit thin but neighbours dad is plumber so will see if he as an offcut i can try ta
            #358451
            Brian Wood
              @brianwood45127
              Surely you will need steel tube for bike frames? The plumber will only have copper pipe.
              Have you tried metals4u? Their website may have what you need.
              Brian
              #358461
                Opps I read it as wanting copperblush
                #358463
                Martin Connelly
                  @martinconnelly55370
                  I think metric tube will be sold with a metric wall thickness. Are you searching for something that does not exist? A quick search on Ebay for 22mm steel tube gave plenty of results with a 2mm wall for instance.
                  Martin C
                  #358477
                  Michael Topping
                    @michaeltopping17870
                    I'm a bit of a cyclist and I have to say that Mild steel is not suited to any part of a bike frame. Have a look at the Reynolds tubing web site they have been around for over 100 years making bike tube sets.
                    Ordinary mild steel will absorb most of the pedalling effort, not transfer it to the rear wheel. I had a bike once made of low grade aluminium tube and that had exactly the same problem, soon got rid of it.
                    Michael
                    #358513
                    Jon
                      @jon
                      This can be a long drawn out affair, size is a nominal dimension within tolerances of the Standards governing body.
                      In the past i have had to buy say short lengths from several suppliers. Sizes vary so buy from same supplier what you need.
                      Worlds your oyster here.
                      https://www.steeltube.sk/list-of-dimensional-standards/
                      I would never advise anyone going to these metal markets the cost is always outrageous and have to collect. Can get three times more for same outlay with delivery from most online places, why bother.
                      ERW, Cold and hot rolled tube wont be round, certainly offset to the bore.
                      #358553
                      mick70
                        @mick70
                        martin have sent email to someone on ebay asking for od cheers.
                        can sand down .2 off 2mm ta.
                        michael i have built about 40 bikes from steel from recumbants to american style choppers with car back wheels for my kids with no problems.
                        my first tadpole style recumbant i built 6 yrs ago is still in every day use by friend i passed it onto and ridden to work 8miles every day by him.
                        i don't know about your normal bikes these days as haven't ridden one years.
                        #358555
                        not done it yet
                          @notdoneityet
                          Are these bikes or trikes?
                          #358556
                          mick70
                            @mick70
                            it's two of these i'm building for mate's who need steering altering to suit their disabilites.
                            normally would weld to std gooseneck but can't this time for way i have to modify steering.
                            so have to scratchbuild.
                            #358598
                            Ian S C
                              @iansc
                              How about old bike frames.
                              Ian S C
                              #358608
                              mick70
                                @mick70
                                cut load up for parts for building them but no tubing that will fit into headstock.
                                guy i'm building one for as no use of left left so will have steering and crank between legs.
                                loosely based on one in pic below.
                                #358735
                                Martin Connelly
                                  Mick70, just make sure you get seamless tube not erw (electric resistance welded).
                                  Martin C
                                  #358750
                                  Tim Stevens
                                    @timstevens64731
                                    The sentence from Michael Topping 'Ordinary mild steel will absorb most of the pedalling effort, not transfer it to the rear wheel' seems not to fit comfortably with my understanding of the properties of mild or any other steel. What else does the energy put in do? Or, which bits get hot? An effort on a pedal will cause the metal – any metal – to spring, and if the effort is too great, it will take a permanent set. Otherwise the spring effect of mild steel is no different from fancy grades of steel – the relevant Young's Modulus is almost exactly the same for all steel.
                                    So, does this mean that a pedal effort on mild steel is enough to bend it permanently? Or what is going on with mild that does not happen with Reynolds ?
                                    Confused of mid Wales – ie Tim
                                    #360965
                                    Paul Lousick
                                      @paullousick59116
                                      I could not find anything on the Reynolds web site saying "Ordinary mild steel will absorb most of the pedalling effort, not transfer it to the rear wheel". (I am interested to see what they say, please advise address).
                                      Reynolds sell tube sets in different materials, including steel. The main advantage in using other materials is weight and unless you are out to break world records is not required. Building from exotic materials would also require specialised equipment for fabrication.
                                      Also confused of New South Wales, ie Paul
                                      #360971
                                        Tim & Paul
                                        I think this is a reasonably well-balanced article on the subject: **LINK**
                                        http://www.bretonbikes.com/homepage/cycling-article-blog/163-steel-tubing-for-cycle-tourists
                                        David George 1
                                          @davidgeorge1
                                          Have you asked Reynolds them selves for help, I know that they have helped groups in the past with donations of tube. They are based at Hall Green Birmingham contact details on there web site.
                                          David
                                          #360973
                                          Paul Lousick
                                            @paullousick59116
                                            Thanks Michael,
                                            I understand all of what is in the link. All basic engineering and common to lots of construction ( have worked in mechanical engineering for 30 years) but what we do not understand is the statement that "Ordinary mild steel will absorb most of the pedalling effort, not transfer it to the rear wheel".
                                            Paul
                                            #360976
                                              Posted by Paul Lousick on 06/07/2018 08:16:45:
                                              Thanks Michael,
                                              Paul
                                              I think it's probably best to put that exaggeration down to 'poetic licence' Paul
                                              Edit: This is worth a look, regarding 'energy absorption'
                                              https://www.sheldonbrown.com/rinard/fea.htm
                                              Edited By Michael Gilligan on 06/07/2018 08:43:04
                                            Home Forums Materials Topics
