My entry for the 2017 Christmas Challenge.
Candlesticks made from mild steel, yellow Dymo tape and acrylic tubing & rod. All found in the scrap box, indeed the candle was marked ‘Decimal currency 2p’, so it is at least 40 years old. The steel bases could also be old CDs. If you don’t have any, get off to your local charity shop and buy a couple of Barry Manilow or Pan Pipes CDs. Either way, they are resistant to tipping, in the choppy waters of the Norfolk Broads or in order to withstand the celebrated Grand Union Bore. They are rather like a Captain’s Decanter, at least if you are captain of a Monitor… I had the had the idea at 7am Thursday morning and the job was done by 5pm. If you don’t ‘get it’, they are modelled on canal boat engine exhaust stacks. My lathe wasn’t big enough to face the ends, not having a Steady, but I realised I could square off the ends in the mill. Acrylic resists burning, but melts, so it should be safe, with care.
Then, on Friday, I had another idea, in collaboration with Mr Kipling, using preassembled foil, pastry, filling, and icing. The cherry was surgically removed and a pin drill used to mount the candle-holder without cracking the icing. This had the advantage that I could eat them afterwards, although the candles were a bit chewy. It took longer to find the Cherry Bakewells in the local shops, that it did to make them into candleholders.
