I am restoring a model of the Aveling DX Road Roller that was build following Edgar Westbury's 1938 article in Model Engineering. The 'Roller had not be used in over 15 years and was missing several parts, not least the ignition system.
Having stripped the model down and cleaned off the rust and removed and checked out the 4 stroke i.c. engine I now have a functioning model. I have added a MinMag ignition system with a hall effect contact system which, along with a new spark plug is working ok. ( With some advice from Julian and Bernadette who run MiniMag on the IOW on the best way to set the system up).
The problem I have is that although the engine kicks over it does not continue (the most life I have had is that the engine kicked over 5/6 times and stopped).
I have checked that the fuel (Aspen4) is being 'sucked' up to the carburettor from the fuel tank, by the simple method of removing the jet screw and with a plastic pipe finding out if the 'petrol' is at the carb.
Does anyone have any experience with this model, and any hints/tips on starting a i.c. engines in general?
Thanks
