To John Rudd … it has been a long time since I have talked about pressures inside gas tanks … thank you for pointing it out … I try to take the utmost care with tank construction … if I look at a plastic tank inside a commercial gas lighter I am horrified … it seems to be from a different world considering the armour plated heavy-weights I produce … many decades ago I was totally unable to find out much information about actual tank pressures and types of available gas jets … with only one exception no-one would tell me anything.
I got so fed up with the secrecy I collected everything together and published it in MODEL BOATS … the June 2005 issue … pages 40 – 45 ( ten years ago ) "gas tanks and burners for small steam boats"
One of the things I discovered was that the actual pressure in a tank 2/3 full of gas was a lot less than the figures I was quoted by the "experts" … I did eventually discover that the figures I was given had been roughly doubled for a safety factor and then, for some reason, they were doubled again … someone else added their own safety factor.
I was expecting hundreds of pounds pressure … the only way I could arrive at approx. 100 P.S.I. was to heat the tank to 55 degrees C … the pressure at 22 degrees C was about 40 P.S.I.
All my experiments were with the tanks 2/3 full of gas … NEVER heat any vessel which is TOTALLY full of liquid.
If this is of use to anyone, all the details are in the MODEL BOATS article.
martin.
