Thank you to everyone who contributed to this thread.
I checked the spindle bearings on my lathe the other night and I can confirm that the large 125mm HBM chuck I've been using (and that's not a lot of use in reality) has significantly worn the front bearing shells on my lathe! I last checked the bearings when I bought the lathe a few years ago and the bearings were in fine condition. That was just before fitting the HBM chuck!!!!
In my opinion the 125mm HBM chuck is too heavy, too bulky and most importantly, it protrudes too far from the end of the spindle for use on the ML7, particularly when compared to the original Pratt Burnerd 4" chucks that were specially made for the ML7.
The 125mm HBM chuck and its backplate literally dwarfs the Pratt Burnerd chuck, and the difference in weight is massive. Further evidence comes form the fact that the specially made Pratt Burnerd chucks have a threaded body rather than a backplate to improve the rigidity on the ML7. So having a chuck that is much heavier and which has its business end much further away from the spindle bearings is not going to help with rigidity one bit!
Just to reiterate – my machine has the original white metal bearings, perhaps the later machines (or upgraded machines) fitted with bronze bearings and hardened spindle may cope better with the bigger chuck.
I've brought one of the Pratt Burnerd 4" chucks that were specially made for the ML7 now (a good second hand item), but part of me feels that RDG owe me a replacement spindle and bearings because they were selling these larger chucks as "take out if the box and screw directly onto the spindle of your ML7 or Super 7" without really considering its suitability for the older machines.
Oh well, you live and learn!
Cheers,
Ross
