On
26 September 2024 at 16:25 Ian P Said:
For the threading to work the die would have to be an unsplit type and very very accurately on centre, or alternatively in a floating holder.
Worked well with the split die I was using in the video
I’ll leave it to you to work out what change of OD there is on a 12BA die when it is closed up by maybe 0.05mm. But bottom edge will still be in the same position and if you apply equal closing amounts to both screws then it will also be in the same position front to back.
The 1.25mm diameter stock is more likely to flex to the die’s position than be cut badly
