Turning between centres on Super 7
Home Forums Beginners questions Turning between centres on Super 7
Viewing 25 posts - 1 through 25 (of 34 total)
  • #9877
    C J
      @cj88518
      C J
        @cj88518
        I plan to turn a part between centres but find the centre protrudes from the faceplate by about an inch which means the peg to push the drive dog round needs to be nearly two inches long and I would like this to be shorter.
        To achieve this, I would like a stubby MT2 centre but did Myford once supply them?, otherwise, short of trying to make one does anyone know of a seller of stubby centres.
        #431241
        Jeff Dayman
          @jeffdayman43397
          Not sure what the issue is with a 2" long peg or stud with nuts for the drive dog. You could also use a bent-leg drive dog with a 2" extension. Have used 2" and longer studs and bent leg dogs many many times with no issues whatsoever. No need to look for special short centres.
          Of course any sort of drive dog turning needs extra care to keep operator and clothing well away from turning parts. Also wise to keep speeds down a bit due to the unbalanced mass. In the old days turners used a boot lace to tie the dog to the stud or a bent leg dog to the faceplate, but these days a nylon cable tie does a nice job. Just be sure to cut the tail off flush with the buckle, don't leave a sharp end.
          #431243
            Shorten it by turning? Ideally need a drawbar, if removing a lot of metal, but that should present little problem unless through-hardened.
            #431246
              cranked leg driving dog will mean you don't need such a long peg.
              Or hold a bit of scrap in the 3-jaw, turn a 60degree point and then use the side of a jaw to drive the cranked dog no drive pin required.
              Edited By JasonB on 30/09/2019 20:08:20
              #431253
              C J
                @cj88518
                Thanks, a few ideas to pursue there.
                I guess I just like the idea of the drive dog being close to the faceplate and away from where I will be cutting. smiley
                #431259
                Mike Poole
                  @mikepoole82104
                  The centre for the headstock should be soft so it can be turned, usually done for perfect concentricity but if you feel it is too long then turn to your desired length. The lathe was supplied with a catch plate which is intended for driving work between centres. You may not have one as they are often separated when the lathe acquires a new owner. For a quick and dirty between centres job just keep a piece of bar with a 60° point and put it in the chuck and skim the point, it will now be dead true, use a cranked drive dog to drive off a chuck jaw.
                  mike
                  Jason beat me to it, must refresh before writingsmiley
                  Edited By Mike Poole on 30/09/2019 20:54:05
                  #431263
                  C J
                    @cj88518
                    Mmm?, after a quick search on the net I see the genuine catch plate (that I haven't got) has a built in counterbalance, which is nice!
                    #431298
                      Just bolt something to the opposite side of your faceplate if you find vibration a problem
                      #431303
                      Mike Poole
                        @mikepoole82104
                        Face DriverOne of these could solve the drive dog problem, they are called face drivers.
                        #431308
                        C J
                          @cj88518
                          Interesting again, I have seen something similar on wood turning lathes,
                          I wonder if you have to give it a tap to make the driving edges bite into the workpiece?
                          #431310
                          Mike Poole
                            @mikepoole82104
                            The chisels are spring loaded and do mark the end face where they bite into the job, sometimes you see the little marks left on the end of a component. They are often used for grinding but they are also used for turning. There are videos on YouTube.
                            #431311
                            C J
                              @cj88518
                              Thanks, I’ve just this minute been watching a video about them
                              #431313
                              Tony Pratt 1
                                @tonypratt1
                                Face drivers would be ok for low torque work but a bit iffy for any sort of cut.
                                Tony
                                #431315
                                ega
                                  @ega
                                  Posted by Mike Poole on 01/10/2019 08:32:24:
                                  Is the centre also sprung so as to take care of the work expanding?
                                  And is there a hobby market for these commercial devices?
                                  #431316
                                  roy entwistle
                                    @royentwistle24699
                                    I think these face drivers are intended for woodwork The only place I've seen them for sale deal with wood turners
                                    Roy
                                    #431319
                                    Mike Poole
                                      @mikepoole82104
                                      I think this may be an hydraulic version but it shows a decent turning cut. They are quite expensive for a commercial item but a shop made version could be made.
                                      #431322
                                        Now that really IS impressive, Mike star
                                        ega
                                          @ega
                                          Posted by Mike Poole on 01/10/2019 10:01:04:
                                          Pursuing my "sprung" query, it seems from the YouTube comments that this one is not spring-loaded. No doubt the significant heat generated is dissipated in the chips/sparks!
                                          #431331
                                          Pete Rimmer
                                            @peterimmer30576
                                            Posted by ega on 01/10/2019 09:46:08:
                                            If the centre was sprung then the part could be ejected under cutting load. The driving teeth are the sprung parts.
                                            C.J. – if you're worried about the length of the driving pin, make a extended driving pin with a fat base and just turn the end that engages the slot in the dog smaller.
                                            Edited By Pete Rimmer on 01/10/2019 12:09:44
                                            #431349
                                            Ex contributor
                                              @mgnbuk
                                              Not on Rohm face drivers – see page 39 on Rohm face drivers
                                              for a cross sectional diagram which shows the spring loaded centre. The centre has to move to allow the part to contact the drive dogs under tailstock pressure.
                                              The Rohm driving disc can "wobble" to take up out-of-square bar ends, which makes for rather pricey items at larger sizes – I have designed a simpler, lighter duty version for turning graphite blanks at work with fixed driving dogs, where an out-of-square end is taken care of by the initially contacting dogs slipping & digging further in to the blank under hydraulic tailstock pressure under cutting conditions. When all 6 dogs are engaged, the blank doesn't slip any further and, as the initial heavy roughing cuts just produce a parallel cylinder, the axial displacement of the blank caused by the dogs digging in under load is of no consequence. The sliding centre is a parallel Morse taper 1 sleeve, with a die spring behind it – the spring rate was determined by trial & error (die springs are suprisingly cheap), with a Morse taper 1 centre providing an easily replaceable "point" if required (which it hasn't been for over 6 years that the home made unit has been in service).
                                              Nigel B
                                              #431353
                                              Mike Poole
                                                @mikepoole82104
                                                Having piqued my own interest in face drivers I stumbled across that same picture Nigel, I can see this might get on the stuff to do list one day. I can also imagine a saw cut across the end of the job could be used to reduce some of the end thrust required. Plenty of food for thought.
                                                #586429
                                                Mike Donnerstag
                                                  @mikedonnerstag
                                                  I just found this old thread on Myford centres, so I thought I'd reply.
                                                  When I bought my Myford it came with many accessories. Among these were three centres that are shorter than standard: soft, hard and half centres. I expect these were originally supplied by Myford to be used with the relatively short pin on the standard catch plate and their bronze drive dogs. Coincidentally, I made a longer pin for the catch plate recently, to work with a standard centre (forgetting I had the shorter centres!).
                                                  I notice from the Myford literature that as well as supplying the standard hard, soft and half centres for metal turning, and the hollow and wood prong centres used for woodturning or with a drill pad, they also supplied square centres and fluted centres. Does anyone know what these were used for? I can't even picture a 'fluted centre'. The square centre had a steep square taper on the front; in fact there is one on eBay at the moment.
                                                  Many thanks,
                                                  Edited By Mike Donnerstag on 20/02/2022 14:52:19
                                                  #586588
                                                    The problem I find with turning between centres with a catchplate or faceplate on the Myford is the gap in the bed. To turn the far left hand end of the job, the saddle has to be half off the bed or the topslide cantilivered way out there. I gave that up as a bad joke and made a drive dog that engages with one of the jaws on the three-jaw chuck. Then just make a quick centre by turning down a piece of scrap bar held in the chuck.
                                                    The drive dog was made from two bits of aluminium 12mm x 50mm flat bar bolted together at a right angle. One side has a hole in it for the job to pass through and bolt to clamp the job in the hole. The other side has a slot cut in it just wide enough to fit over the chuck jaw so it is not flapping around loose. Works a treat.
                                                    #586642
                                                    bernard towers
                                                      @bernardtowers37738
                                                      Sorry chaps but between centres turning is what it says anything else is not.
