What to look for when buying WW collets
Home Forums Beginners questions What to look for when buying WW collets
  • #9825
    Chris TickTock
      @christicktock
      Chris TickTock
        @christicktock
        from the web:
        ww collets can be 0.275" x 40TPI or 6.985 mm x 0.635mm pitch
        However F.W Derbyshire still manufactures to original spec of;
        0.625 mm pitch and 60 degree thread.
        Baring in mind I have a sherline lathe what are the implications of these different specs for working with on the lathe?
        Chris
        #426073
          As you recently mentioned already owning some WW collets: It would be worth checking the details of those, and making up a set that match.
          Do you have a draw-tube for yours … and does it fit nicely ?
          P.S. This book is 'definitive' on Moseley and Webster Whitcomb:
          https://archive.org/details/watchmakerslathe00good
          I recommend reading all of it, thoroughly … but you might want to look at Chap. III first.
          Edited By Michael Gilligan on 26/08/2019 13:43:36
          #426076
          Anonymous
            On the Sherline website there's a page that talks about WW collets and which makes fit, and which don't!
            #426079
            Chris TickTock
              @christicktock
              Posted by Andrew Johnston on 26/08/2019 13:45:07:
              Thanks Andrew just come across it .Starret seem best choice if buying in older collets others will work but needing an adapter.
              chris
              #426081
                https://www.sherline.com/product/individual-ww-collets-copy/
                From which I note that Sherline's own are not hardened sad
                But at least they are modestly priced, compared to Levin's smiley
                Those of a nervous dosposition might want to sit quietly in a dark corner before looking here:
                https://levinlathe.com/page23b.htm
                Edited By Michael Gilligan on 26/08/2019 13:58:20
                #426082
                Chris TickTock
                  @christicktock
                  Posted by Michael Gilligan on 26/08/2019 13:24:25:
                  Thanks Michael.I have a set of ww collets from sherline however price wise I will do a comparison, but you are right and I am already making such enquiries.
                  Chris
                  #426083
                  Chris TickTock
                    @christicktock
                    Posted by Michael Gilligan on 26/08/2019 13:56:15:
                    Thanks Michael I was told Sherline were not hardened but my reports are they have lasted well despite this for the use they were put to. unfortunately I missed the fact Sherline stated so but am not unduly bothered at this point. I may well do some reading as you suggest.
                    Chris
                    #426158
                      Chris from your clasified you say "Sizes needed metric from #3 to #53" can I ask where you have come up with these "metric" sizes from?
                      I fear you may again be looking at American books by your use of # where here in the UK we tend to use No. for number. If you indeed mean number sizes then these are not metric so you also need to look for the correct sizes when buying collets.
                      Number drills are becoming obsolete but still crop up in old books and on old drawings, you would be better off getting drills in 0.1mm increments and then if you need to hold shafts to fit these try and find metric collets to fit or go to a small ER type collet system where each collet covers a range of sizes.
                      #426172
                      Chris TickTock
                        @christicktock
                        Posted by JasonB on 27/08/2019 10:17:16:
                        Your half right Jason thanks. Sherline part Numbers for their metric WW collets tally with the size. So ######3 is 0.3..and #####4 is 0.4 and so on. So I am looking for Starrett mm WW collets to use on my Sherline lathe sizes 0.3 to 5.2mm. Can I change the advert?
                        Chris
                        #426176
                          To edit adverts click "classifieds" along the black bar top of page and to the right will appear "manage my adds"
                          #426178
                          Chris TickTock
                            @christicktock
                            Posted by JasonB on 27/08/2019 12:56:46:
                            Thanks all done.
                            Chris
                            #426224
                            roy entwistle
                              @royentwistle24699
                              Jason    According to Donald de Carle ( the Clockmakers Lathe ) in the numbering sytem for WW collets the number equals 1/10 mm
                              Chris       Crawfords were a well known maker of collets as well
                              Roy
                              Edited By roy entwistle on 27/08/2019 17:58:21
                              #426239
                                Thanks for the info Roy.
