I haven’t built either Minnie or Tich, but I have the books for both and have been through them with a fine tooth comb. My two cents below – your mileage may vary.
Minnie in my opinion is a better quality design. Mr Mason has included many diagrams and photos of layouts and work holding/machining ops, rather than just word descriptions and the very few sketches of such items in Tich plans. (other feature related reasons – see Tich issues below). Lots of very small parts, but that should not put you off if you are patient. The pump issues mentioned above should be resolvable with some fooling around with spring force and ball/seat size and travel, but lots of experimentation may be required to zero in on optimum sizes/lengths. Heat could be a factor too – reciprocating pumps will not easily pump hot water, and the pump being stuck to a hot lump of copper boiler means it surely will be warm. Maybe a thermal isolating mount for it somehow could be implemented. The only major thing that would make Minnie easier would be building the engine on an engine frame and using a separate steam dome rather than the cylinder block, like USA traction engine practice. This would simplify things considerably, but it wouldn’t be an English design traction engine anymore. As I recall there are several bushings called out as brass, in my opinion only good bronze should be used for bushes on rotating shafts. Also cast aluminum T rings are called out for the rear wheels, I would say built up steel wheels from rolled steel rings and waterjet cut steel disks, all silver soldered up, will be much better and maybe cheaper than aluminum T rings.
Tich is a very small locomotive. I have seen people struggle mightily to coal fire it with success. In addition the throttle / regulator is one of the worst designs I’ve ever seen for one. There are also many known published plans errors for Tich on Alan Stepney’s site. The regulator issues could probably be solved by installing a smokebox throttle. One good and proven such throttle is a Swagelok ball valve (high temp rated model) but space is small for this in Tich so it might take some fiddling on a CAD system to shoehorn it in. If it won’t fit, a screw down needle style throttle would be easy and will work fine. If I were building Tich, I’d go with the Baker valve variant for easier build, and the open cab variant, for easier firing. Speaking of firing, maybe a two slotted tube or ceramic element gas burner as used in gauge 1 models would be easier for a beginner to make and use rather than coal firing. After all the firebox of a gauge 1 big loco like a 4-6-2 or 2-10-0 is around the same size as a Tich firebox, and the gas burners work fine for the big gauge 1 models. Check out Roger Thornber’s locos in ME for details on these gas burners.
It’s too bad someone hasn’t done a design for a narrow gauge open cab outline loco, like Terry Aspin’s Charles 0-4-0, for 3 1/2″ gauge. (or have they?) This would give an equally simple to build and low material cost loco for beginners but the boiler would be just that much bigger as to have more room for a simple smokebox throttle and would be easier to fire on coal. Food for thought. Doesn’t need to have a saddle tank, either, it could be a tender loco for simplicity.
JD
