Lady Stephanie
Lady Stephanie
Home Forums General Questions Lady Stephanie
  • #794680
    Steve Huckins
      @stevehuckins53362
      Can anyone give me their thoughts and advice on the ‘Lady Stephanie’ engine advertised by ‘Reeves’ please ?
      I am relatively new to model engineering but have completed a few Stuart engines as well as a PM research PM1
      I like the look of the ‘Lady Stephanie’ engine a lot from the pictures but have heard some troubling reports about the quality of the drawings.  Also some issues with Reeves service.
      The kit is just shy of £300 with the drawings so I am not going to go ahead and purchase one without some feedback from anybody who has built one.
      Cheers
      Steve
        It would be quite a step from what you have made to lady S. being a small engine with a lot of detail many of the parts are quite small as are the fixings.
        I would be tempted to see if you can pick up the old issues of EiM from ebay or similar to see what is involved and the build article will be a lot of help too.
        These days with many of us having milling machines it may be better to cut some of the items from solid rather than use castings just picking the more difficult to make ones like the beam and flywheel.
        If it were me I’d make from scratch at a larger size and pick a few details from some of the other coffer based six column engines images of which can be found on the net.
        #794692
        John Purdy
          @johnpurdy78347
          Steve
          The build series in EIM ran from Nov. ’81 to Jan ’83 Vol. 3 #6 -#12 and Vol. 4 #1- #8.
          alan ord 2
            @alanord2
            Hi Steve, I built Lady Stephanie and concur with Jason. Some of the parts are very small and fidly but technically not too dificult to make. The only issue I had with Reeves was that there is not much excess material on the casting’s for finishing the machining. So you need to be carefull with your set ups. That said if you are carefull the casting’s can be machined to size. If you do decide to go ahead and make one and if you need the build article’s I can forward them to you. I did not have any problems with drawings as i used the drawings in the build articles.
            P.S. If my avatar photo comes up it shows Lady S that a built.
            Alan.
