Sieg SX2P – DRO, power feeds, CNC? What first?
Home Forums CNC machines, Home builds, Conversions, ELS, automation, software, etc tools Sieg SX2P – DRO, power feeds, CNC? What first?
  • #792794
    nevillet
      @nevillet
      Hi all,
      I’m looking at getting a 3-axis DRO for my very compact SX2PG mill.
      I also want to get a power feed for the X travel – and possibly the Y and Z.
      …and possibly in the future I could add PC controlled CNC functionality…
      I have several questions:
      What are the general considerations?
      What are the order of works for something like this?
      Are the relatively cheap DRO’s on sale on Ebay appropriate and any good for a mill like this?
      Being such a small mill, is adding all the hardware required for CNC just too cumbersome and OTT?
      Any thoughts or pointers would be great.
      Many thanks.
      Clive Brown 1
        @clivebrown1
        I have a Warco 16b mill, slightly larger than the SX2. A 3 axis DRO is an excellent upgrade. I purchased from Ebay and am satisfied with price and quality. Bear in mind that the supplied bracketry will almost certainly be of litte use for your particular installation and some self-manufacture will be needed which will take time and some ingenuity.
        Also bear in mind that the usual glass scales take up proportionately more space on a small mill. Perhaps not an issue with X and Z travel, but more so with the Y travel where you will lose some movement.
        Can’t really comment on power feeds but I don’t really feel the need for them, particularly Y and Z.
        #792806
        John Haine
          @johnhaine32865
          A DRO for me is a must, I have a Machine DRO mag scale type fitted to my VMB and wouldn’t be without it now.
          Autofeed on the X axis is very useful, reduces handle turning tedium and gives a better finish.  One approach to that is to fit a stepper and control it using GRBL which is an open-source CNC program that can run on an Arduino.  Once you do that if you want to go the whole CNC hog you have a starting point.  The next axis (if you don’t go full CNC) would be Z for boring.
          No reason that the size of the mill precludes adding CNC, I also have a small Denford Novaturn which is smaller than the SX2 (but much more rigid) and it’s very useful.  Looking at the specs for the SX2PG though it seems that the vertical feed is via rack and pinion?  Unless you have ball screws on each axis CNC would be pretty difficult  so adding a Z axis leadscrew would probably be needed.  Fitting ballscrews to the SX2 could be tricky and would probably need another mill to do the mods!
          #792808
          Zan
            @zan
            Do one or the other, Power feeds and DRO  all come with the cnc conversion. So adding motors for power feeds is wasting money if you ever go for the cnc conversion
            See  ME from march 2019 for details of how I converted mine. It’s a long interesting process, but it makes a great little cnc machine, with a highly satisfying work envelope
            however it’s only cnc now, difficult to get manual/cnc usage on this machine
            #792812
            Zan
              @zan
              Ah John is correct another mill is needed esp for the mods needed to the saddle  there’s not much room in there for mounting the ball screw nuts
              I used a fixed ball screw to the head for the z axis
              if you just go for the dro, what about the self adhesive magnetic type, mentioned by John are so much smaller than other types , esp glass scales
              #792825
                DRO would be the first one using magnetic tape, if like the SX2.7 then the read head fixings are already there. But you won’t need that with CNC as you will get a readout as part of the CNC controller.
                Similar with Power feed, you could fit a similar unit to this or make your own. If you are going CNC then use the stepper for that to give you the power feed and then you only have two other axis to think about when you go full CNC.
                The XZY envelope is large enough for CNC just set your cutting parameters to suit the abilities of the mill.
                #792835
                  DRO is a no brainer.   Before understanding that, several years ago I fitted my mill with Arc Euros cheapest offering, a pair of these:
                  arceurodro
                  Didn’t expect them to last, just fitted as a proof of concept, to be upgraded later if valuable.  They work very well, and have continued to do so.   They don’t have any clever functions, and having two displays isn’t ergonomic, but they still transform the mill!  When one breaks, I’ll be into glass scales etc, but so far the pesky things refuse to die.
                  I’m on the edge with power feed too.   Mainly take short cuts rather than long sweeps, so bearable.  Nonetheless I’d probably have upgraded had not illness and other distractions kept me out of the workshop.  Or gone CNC.
                  CNC is very tempting.  I originally saw CNC as only valuable for repetition work which I rarely do.   But CNC also pairs well with CAD, allowing the designer to specify cuts moving simultaneously in 2 or 3 dimensions.  These are all but impossible to do manually.  Starting again today I would immediately go CNC because I’ve realised not having CAD & CNC is holding me back.   (Learning to drive 3D-CAD is a major investment too.  Already have it for other reasons, so not an obstacle for me.)
                  duncan webster 1
                    @duncanwebster1
                    It’s always tempting to feed too slowly by hand, resulting in blunt cutters. I’d fit a stepper motor driven X feed which can be used later in CNC if you go that way. If you’re not going CNC straight away, as others have said DRO is a no trainer.
                    #792867
                    nevillet
                      @nevillet
                      Thanks for all your advise.
                      So plan of action:
                      1.  DRO
                      2.  Stepper motor based power feed on Y-axis
                      3.  Stepper motor based power feed on X-axis
                      4.  Stepper motor based power feed on Z-axis
                      5.  Possible CNC ???
                      Looking at the various DRO’s on Ebay it appears there are two styles of interface.
                      One type is what i’d decribe as traditional with the 3-axis read outs on LED’s and a multitude of buttons.
                      Screenshot 2025-04-11 153210
                      The other version looks smaller in scale and has a full digital display with F keys for selecting functions.
                      Screenshot 2025-04-11 153536
                      Apart from space saving of the second type are there any pros/cons to consider?
                      #792871
                      Peter Cook 6
                        @petercook6
                        Neville, I fitted a 3 axis DRO to my SX1LP, which I think has the same XY table as your SX2. There are some pictures here of my installation. The rest of the thread is the one I found when looking for inspiration. I bought glass DRO scales and the bigger display you mention direct from Ali Express for just over £200 delivered, and they were all great. The only error I made was getting 1micron scales instead of 5 micron, but they work extremely well and make the little SX1LP a pleasure to use.
                        I was able to engineer the Z axis scale so that it reads the actual head position, that gives me Z axis plus the quill movement which is handy, but I don’t think your SX2 has a separate quill so that will be less of an issue.
                        #792918
                        Huub
                          @huub
                          I have had the cheap igaging DRO’s (same as @sillyoldduffer) on my mini mill for more than 6 years and they work flawlessly. I will convert my new mill to CNC but even then, want to use the mill manually so I did mount the same type of DRO.
                          I use a vice for most of my parts I make. The back left corner of the vice is my zero point.
                          If I move the battery powered igaging dro, even when switched off, the DRO will record the move. All 2/3 axis DRO’s that I have found, needs to be switched on (display can be dimmed) all the time or such movements will not be recorded. I can’t use these mains powered DRO’s because I switch off the power when I leave the shop.
                          I have read that there are absolute DRO scales that can be safely moved when switched off but I couldn’t find these. They are probably not for a hobby budget.
                          #792921
                          howardb
                            @howardb
                            arceurodro
                            I have the same ArcEuro basic DRO on the Myford S7B on the Z axis – saddle/carriage travel and it’s very good.
                            The motivation for this was previously machining a replacement poly-V pulley for a planer/thicknesser with a pitch between the grooves of 3/32 – 0.09375″ using the leadscrew handwheel@ 0.125″ per rev, backing off using the topslide @ 0.03125″ to get to the required 3/32 tool travel while retaining the zero point.
                            What with interruptions and phone calls you can see why I went for a DRO.
                            As long as you take care to shield the scale from swarf/coolant/cutting oil and arrange a saddle travel end stop to avoid wrecking it,  they are as good as any DRO.
                            #792981
                            nevillet
                              @nevillet
                              So I’m now looking at DRO’s on Ebay & AliExpress.
                              More questions…
                              1.  The encoders seem to be optical devices – does that not present potential probles with detritus getting in the sensors?
                              2.  All of the head units apear to use 9-pin D connectors for the encoders. Does that mean there is a common standard between head units and sensors?
                              #792987
                              Peter Cook 6
                                @petercook6
                                Q1 Good practice is to fit the scales so that the opening along which the sensor head slides is facing downwards, and then fit chip guards over the scale. Most scales will come with an aluminium chip guard, although they are quite bulky and eat space on a very small mill. I intended to fit some plastic angle over my scales as being neater – however I still haven’t got round to it and things are working OK after a year, although I do hoover the mess up after each job and don’t use flood coolant – just a paint brush!
                                Q2 The consensus seems to be that there is no standard convention for the pin-out on the D-sub connectors. Kits bought from one of the big boys should be fine – or you send them back. Buying on a mix and match basis from china is probably a bigger gamble unless the vendor can provide the pin-outs. There are posts on the internet describing how to diagnose them, and then resolder the plugs to match your head unit. That said the scales and head unit I bought (from the same China vendor) worked out of the box.
                                #792989
                                nevillet
                                  @nevillet
                                  Hi Peter,
                                  What are the dimensions on your DRO head unit?  (every mm counts around here…)
                                  #792992
                                  Peter Cook 6
                                    @petercook6
                                    This is the install drawing.
                                    DRO Drawing
                                    It corresponds to mine except that the arm length on mine is 373 rather than 417.
                                    The depth of the head unit is right at 78, but you need to allow another 70-80 behind that to allow for the D-Sub plugs and armoured cables. I have mine mounted to the wall at the back of the mill. The pivot on the wall is 220mm from the centreline of the mill, and the arm is usually at 45degrees
                                    DRO positionDRO side view
                                    If you are passing anywhere near Hungerford I would be happy for you to drop in and have a look.
                                    #793011
                                    nevillet
                                      @nevillet
                                      The orders in for the DRO.
                                      I’ve gone for a UK based Ebay supplier and ordered the TFT version DRO along with the axis scales.
                                      Order value was £285.
                                      https://www.ebay.co.uk/itm/124772884635
                                      I went with Ebay because:
                                      Local support and returns will be easier & delivery will be about 3 days.
                                      I’ve purchased from AliExpress in the past but it’s been for small hand tools and never anything as complex as this.
                                      Many thanks for your kind offer Peter – similarly, if your ever in Southampton…
                                      #793014
                                      Clive Brown 1
                                        @clivebrown1
                                        I purchased from that same supplier about 3 years ago. Smooth transaction and, so far, no problems. Nice to see that they’re not “fly-by-night” operation. Also prices seem to have changed very little. The LCD display is, IMO, the better type due to its greater versatility in displaying graphics and suchlike, esp when using the different programmed features.
                                        #793016
                                        Martin Connelly
                                          @martinconnelly55370
                                          I would just like to add that if you set up a machine for CNC and have a controller that allows manual data input (MDI) and use of a pendant with a manual pulse generator (MPG) you only need to know a few G codes to use it like a manual machine. This would, as stated above, render the external DROs redundant, along with the handwheels.
                                          By a few G codes I think G0, G1 and F cover almost all manual movements.
                                          Martin C
                                          #793039
                                          nevillet
                                            @nevillet
                                            Thanks all.
                                            I struck me that coming from a experience level of zero with mills, DRO’s and machining in general, the GUI of the DRO I purchased would help.
