James Coombes Drawing Error (or mine?)
Home Forums Drawing Errors and Corrections James Coombes Drawing Error (or mine?)
  • #792062
    Steve Withnell
      @stevewithnell34426
      I finally got round to putting the James Coombe back on the bench.  It’s mainly all done now, but the fitting shows this, which I think is a problem.   Pretty sure that’s going to clash “in service”.  I can’t find an error in my parts, despite lots of measuring,  anyone else built one of these?
      If there is an error, how do I correct it?
      Coombes
      Martin Connelly
        @martinconnelly55370
        This is the Stuart version, similar small clearance.
        Martin C
        P1010200
        #792069
        Diogenes
          @diogenes
          Even a small chamfer or radius on those meeting edges would likely give enough clearance?
          #792071
            With the “hump” left on the bearing there is really no clearance as it is about 7/16″ radius. Correction may be to flatten the top as martin’s picture shows. Alternative is to make the short lower bigend section a bit longer and shorten the piston rod but do check movement of the cross head guides. If not its a whole new conrod with longer bottom and shorter top bits
            I modified mine quite a bit so have the hump, boss for an oiler and a short oilcup, this is at it’s lowest point.
            jc clearance
            #792073
            Steve Withnell
              @stevewithnell34426
              Thanks.   I’ll complete the trial fit and see if enough clearance can be teased out without looking bodged.  If not sounds like re-making the short conrod a bit longer.   I could then add square plates to the bottom of the columns as in Jason’s drawing, to compensate. The strap for the eccentric isn’t cut yet, so that sounds like a decent plan B.
              Thanks all.   I didn’t spot the similar issue with the bearing height on the Victoria either!   Next time, I’ll take more care over checking the drawings…
              #792161
              Dave Halford
                @davehalford22513
                Exactly,
                I would make the bearing look a little more like a Victorian casting and remove all the sharp edges. I like Martins fillets as well.
