Ignition for Stationary engine
Home Forums Stationary engines Ignition for Stationary engine
  • #789246
    Dalboy
      @dalboy
      As some know I am building the Farm Boy hit-and-miss engine. This is something I should have thought of earlier in the build but I got carried away making it.
      What type of ignition system is best for this type of build, any recommendations and sources for one to suit. I don’t really want to send abroad for one unless I have to.
        In that case you will have to consider IOW as being mainland UK and go with Minimag.
        #789257
        Durhambuilder
          @durhambuilder
          #789338
          Dalboy
            @dalboy
            Thank you both, will check them out later today
            #789344
            Ian Hewson
              @ianhewson99641
              Bought one of the cheap Chinese ones off eBay, had poor results, then bought the mini Mag. After a couple of turns either a finger over the carb intake to choke? It starts and runs very well.
              It may pay you to get a few different types of o ring to start with, as the first one I used only lasted a very short time. I replaced it and now it is fine. Others seem to have had this issue also.
              I run mine on Methanol with good results
              Good luck.
              Ian
            Home Forums Stationary engines Topics
