Good supplier of bandsaw blades please
Home Forums Workshop Tools and Tooling Good supplier of bandsaw blades please
  • #788539
    Martin Johnson 1
      @martinjohnson1
      I used to get my 64 1/2 inch x 1/2 wide blades from Screwstation but they stopped them.  I use them on both my horizontal 6×4 and my homespun 3 wheel vertical.
      My last lot were from ebay and are wafer thin, no set to the teeth and covered in vaguely slippery plastic that wore off in no time – in short, total rubbish.
      Can anybody recommend a supplier of ready to use blades in 10 and 14 tpi options, please?
      Thanks,
      Martin
      Dalboy
        @dalboy
        I have always got mine for my wood cutting bandsaw and metal saw from Tuffsaws always had a great service. If you have a quiry then you may need to phone a couple of times as he is a one-man band but always knowledgable
        #788543
        Roderick Jenkins
          @roderickjenkins93242
          As well as Tuffsaws I’ve also had good service from Mister Bandsaw on ebay
          https://www.ebay.co.uk/str/misterbandsaw?_trksid=p4429486.m3561.l170197
          Rod
          #788544
          Mike Hurley
            @mikehurley60381
            Bedford saw have always given me excellent service over the years
            #788545
            Trevor Johnson 1
              @trevorjohnson1
              You could try Axminster Power Tools, they make their own blades on site to order, any length/tooth pattern usually.
              Good Luck
              TJ
              #788546
              Brian Wood
                @brianwood45127
                Tuffsaws sell the bimetal blades that are greatly superior to plain carbon steel versions, especially when cutting demanding materials. I have had excellent service life from them and use 10 tpi blades for most work; 14 tpi on thin walled tube.
                Brian
                #788549
                Jim Nic
                  @jimnic
                  +1 for Tuffsaws.  Brilliant service, I had ordered a blade of the incorrect length but when I contacted him he resized it and returned it to me for no charge.
                  Jim
                  #788559
                  Oldiron
                    @oldiron
                    Mrbandsaw on Ebay are always my goto supplier.
                    #788561
                    DC31k
                      @dc31k
                      How is the ethnic origin of your bandsaw relevant to the blades that will be used on it?
                      #788563
                      bernard towers
                        @bernardtowers37738
                        i use Norfolk saw services they match any prices and they are only a couple of miles away.
