I’ve often wondered how this is done in the factory. I can’t imagine them fiddling with a DTI to tram the head as we do.
As assemblers are unlikely to be skilled, I guess the answer is a jig. Something hefty that aligns the machine’s base and column so all the assembler has to do is tighten the bolts. The jig might have a few built-in dials for fine adjustment.
The resulting alignment is ‘good enough’ provided the mill’s components are machined sufficiently accurately. Several problems: if the machining is too crude, the head could move in transit or whilst cutting. And if the mill is dismantled, we have to tram it the hard way without a jig with fiddly adjustments to a column that can move. And those fine adjustments are made with crudely made nuts. All a bit yuk. Industrial mills are machined more accurately, but that adds hugely to the cost, putting new machines well beyond most Model Engineering budgets.
Can’t think of a way of extemporising a jig. Too big, heavy and accurate to make in my little workshop. And having made one, it would only get used once in a blue moon. More practical to tram by fiddling and cursing for as long as it takes!
In 10 years I’ve trammed my mill 3 times. Not because the factory setting is bad, but because the head can swivel on a bolt to cut at an angle, which is handy sometimes. This is pretty crude, I think ‘too simple’. It works, except putting the head back square is a pig. Once, the thing went back in 10 minutes, but my last attempt took a day because it moved when the bolt was nipped up at the end.
Since been advised on the forum to do it by bringing the head flat down on the table, and then tightening up. Not needed to try it yet, but should help considerably when the time comes. Might even be how heads are aligned in the factory: the table is a flat reference. Wouldn’t be as quick as the jig I imagined above though, because a jig reduces freedom of movement much more.
Anyone know?
