Resize photos W11
Resize photos W11
  • #787271
    duncan webster 1
      @duncanwebster1
      On W10 I downloaded a little program which, when you clicked on a photo, gave you the option to resize it. I’ve now gone over to W11. Searching the interweb says I should open the picture in photos, then click the 3 dots in the top right and it will give me the option to resize. Well my version of W11 has 4 dots, and doesn’t have this option. I don’t want to do anything clever, just reduce the size for inclusion in newsletters etc. The W10 version let you do several at once. Anyone got any bright ideas?
      peak4
        @peak4
        By far the best cheap/free program I’ve used for such jobs is Faststone Image Viewer.
        It does what you require singly, or as a batch, but is far more powerful when needed, including image editing and enhancement, drawing plus captions/annotations & screen captures; it even recognises many raw files.
        Free for private use, though personally I add a small donation when a new version appears
        https://www.faststone.org/FSViewerDetail.htm
        Bill
        #787284
        Gary Wooding
          @garywooding25363
          I’ve used Irfanview to resize photos for a number of years now. It can do a few other good things too, and its free for non-commercial use..
          #787288
            I use “Paint” to resize / crop photographs. (But being a Luddite am still using W7 Professional, so it may not function as well, if at all, on “improved” programs)
            Son in Law said that every time Microsoft introduce some update or modification, there is a downside, so I stick with what works!
            But, then, I am not interested in super high speeds, gaming or streaming.
            #787297
            Nicholas Farr
              @nicholasfarr14254
              Hi Duncan, my W11 allows me to resize photos, I just click on a photo and there are three dots at the top R/H side of the screen.
              Screenshot (1)
              Clicking on the three dots brings up a drop down menu, with the resize option, and clicking on that brings up the resize pane.
              Screenshot (2)
              However, I don’t think it is as good as the W10 one though, as I can’t see the option for making web size photos etc.
              Regards Nick.
              #787312
                The ‘4 dots’ is different from mine which has 3 dots upper left and another 3 dots lower right when in not full screen mode. Both when moused over say ‘see more’ but the bottom right one is just a slider for current magnification on screen. It might all depend on your window size and display settings to do with how much it can fit on the screen at your current icon size.
                In paint it is still there but obfuscated by being and icon of one square inside another which looks more like it is just a ‘full screen’ selector.
                #787314
                John Hinkley
                  @johnhinkley26699
                  I couldn’t get on with the Photos program in Windows 11 when it supplanted Paint, so I installed Paint legacy from:
                  Paint legacy download link
                  This “old” version of the image manipulation software doesn’t have all the fancy twiddly bits of the latest, but just does the simple things that I require.
                  Note:  This is not a Microsoft site, so the usual precautions apply.  Having said that, I’ve been using it for various applications and have encountered no problems.
                    Windows 11: Right click in file manager, choose open with ‘photos’, then click the three dots at the top and choose resize.
                    For good but slightly too small photos, I usually resize in Affinity Photo, and for tiny thumbnails and fuzzy originals I have invested in the Topaz AI suite. The latter can usually make pigs ears into linen, if not silk, purses.
                    Martin Connelly
                      @martinconnelly55370
                      I’ve never resized photos like this. The programs I have used let you resize in place. Word, Publisher and their non-microsoft equivalents do not require a specific size photo to put them in place at the size required for the available space. Just click on the photo and use the handles that appear at the corners to enlarge or reduce as required. What are you using to produce this newsletter?
                      Martin C
                      #787382
                        The OP did mention that he is seeing 4 dots not the normal 3 dots so that is something odd.
                        I checked on my laptop that MS photo editor does still have 3 dots if made full screen but if the window  is shrunk and shrunk it produces another set of 3 dots and then another when there is no room for all the action icons.
                        Not resizing photos in a newsletter can make the file rather big, depending on program, which is not very customer friendly. Even though now few people are using dial-up it does use up some people’s mobile data unnecessarily.
                        It would be interesting to see an example of this Topaz picture enhancement……..
                        #787388
                          For heavy duty image processing, ImageMagick does the job.  Point and click is great for tweaking a few images, but if hundreds or tens of thousands are to be processed, then go for a tool that can be scripted.
                          ImageMagick provides a command line tool called ‘convert’ or ‘magick’ that takes multiple options and can operate on lists of images.  Resize is one of 5 transforms provided, and transform is just one of 40-odd other image operation groups supported.
                          Rather simple when you know how to resize all the images on a computer and then montage or animate the result.
                          Need to convert an US Mil Standard CALS file to a TIFF – no problem.
                          This bad boy is typically behind the scenes on a web-server or photo repository. Key advantages: comprehensive, can be automated, and is made to handle images in bulk; powerful!  Disadvantages: though simple usage is straightforward, users have to learn how to drive and have a good understanding of image processing for advanced work.   Scripting not ideal when a single image has to be tarted up experimentally, because a point and click interface often supports suck it and see better.
