As promised some measurements. I’m surprised!
Be warned: don’t read this if you like to believe British made stuff from yesteryear is high-quality compared with modern rubbish!
Here are the examples:
1. 1950/60 British.
2. Modern plastic, circa 2000.
3. 1970-ish British, Aluminium, very common (2 examples):
4. Metal recent, foreign made:
In general these are not precision made! The pins and bodies are not round, and sizes vary considerably on the same plug and in comparison with others.
1950’s British, with silver plate. Body 9.32, 9.46, 9.40, 9.55, variance 0.23mm. Pin 2.40mm
1970’s Aluminium. British. Corroding.
- Example 1: Body 9.54, 9.59, 9.55, 9.52 variance 0.07mm. Pin 2.35, 2.33, 2.32, 2.37 variance 0.05mm. Crudely threaded, hard to assemble
- Example 2: Body 9.46, 9.45, 9.47, 9.46 variance 0.02mm. Pin 2.49, 2.35, 2.41, 2.37, variance 0.14. Clean thread,
Plastic Modern circa 2000: Body 9.53, 9.56, 9.54, 9.47 variance 0.09mm. Pin: 2.37
Metal Modern, recent purchase: Body 9.49, 9.48, 9.47. 9.50, variance 0.03mm Pin: 2.36, 2.26, 2.25, 2.26 variance 0.01mm
These plugs aren’t made to high tolerances! Though they look similar one British Aluminium plug is more accurately made than the other.
And although the silver-plated plug looks good, it’s dimensionally poor compared with the Aluminium plugs. The plastic modern plug is slightly worse than them, but the best is the recent purchase.
Body dia should be 9.525mm. Mine are mostly under that, except for a couple of fat spots, probably due the body not being round.
Pin should be 2.35mm. Again, my examples are mostly undersized, with a few fatties.
Conclusion: with one exception, possibly lucky, my sample plugs clearly aren’t precision made! Therefore expect some loose and some excessively tight fits. I guess Michael’s TV has a sprung tight socket, and his plugs are all fatties apart from the Maxviews. I must have used hundreds of Belling Lee plugs over the years and not had a problem, but…
