Another Fobco Chuck
Another Fobco Chuck
Home Forums Workshop Tools and Tooling Another Fobco Chuck
  • #785412
    spencerd72
      @spencerd72
      Dear all,
      I have no idea how to remove the chuck from my recently acquired Fobco Star 9see pics below).
      I have seen an old post in this parish where there was a knurled ring that unscrewed and pushed the chuck off. My drill does not seem to have this. Any ideas?
      Many thanks in advance,
      Dominic.
      20250224_11550520250224_115514
      noel shelley
        @noelshelley55608
        Extend the quill and see if there is a slot in it – if so then it will be 2MT and need a tapered drift to push the 2MT shank out of the quill shaft. If not then a Jacobs Taper in the chuck, the chuck may have this fact marked on it. Gentle heating and a forked drift should get it off, patience is needed. Good Luck. Noel.
        #785444
        spencerd72
          @spencerd72
          Many thanks Noel,
          There isn’t a slot, even with the quill extended, so I suppose it’s a case of getting a good forked wedge and tapping with some heat.
          I can’t see any markings on the chuck to describe the taper. It says it’s British made, in Sheffield, shows the capacity and says it’s a Jacobs number 34.
          Thanks again from the reply.
          Dominic.
          #785464
          noel shelley
            @noelshelley55608
            Dominic, whilst I would expect it to be a JT I have seen ones with an internal thread, I bought one in the early 70s to fit a Myford, but it told me the thread – you say yours has no info. Noel.
            #785481
            peak4
              @peak4
              On spencerd72 Said:
              Many thanks Noel,
              Dominic.
              As far as I can see, all Jacobs 34 are all tapered fit, in the current range anyway.
              http://www.jacobschuck.com/plain-bearing-keyed/17.html
              Really, I believe you should uses opposed tapered wedges, specifically for the purpose, rather than just hitting on one side with the likes of a ball joint splitter.
              http://www.jacobschuck.com/uploads/ueditor/file/20200604/1591240204146153.pdf
              image_2025-02-24_150119602
              They are available, but come at a cost.
              http://www.jacobschuck.com/search/index/tag/id/97.html
              Bill
              #785502
              Clive Brown 1
                @clivebrown1
                Dominic.
                No. 34 indicates a chuck with a J6 taper IIRC. If it were screwed it would be 34B.
                A long time ago I removed my taper mount Fobco chuck very quickly by trying to use the machine as a vertical mill!
                #785541
                spencerd72
                  @spencerd72
                  May thanks for all the replies.
                  I’ll have another look and let you all know how it goes.
