Securing smokebox number plate
Home Forums General Questions Securing smokebox number plate
  • #783174
    Derek Drover
      @derekdrover32802
      I have obtained a brass numberplate for my 5″ L1, to go onto the smokebox door, but I’m worried about how to secure it. I have a hole already in the door to take a 5Ba screw, so I’m considering soldering a brass countersunk screw to the back of the brass plate using Comsol.
      My worry is the temperature the smokebox could get to when running.. will the Comsol hold ??
      How have others secured theirs?
      parovoz
        @parovoz
        My £0.02
        Assuming the number plate is not painted, just use silver solder. Then guaranteed secure at all smoke box temps. I once saw a comsol soldered chimney band ping off due to melting. Engine was working pretty hard though….. I have also riveted this kind of stuff in place with fine 3/64″ brass rivets then carefully countersunk and dressed off a the front. Then paint it and nothing shows.
        #783204
        Speedy Builder5
          @speedybuilder5
          Question is – how were they originally attached, I doubt cosmsol or silver solder.
          Bob
          #783215
          bernard towers
            @bernardtowers37738
            As Paravoz  use rivets fit and forget.
            #783299
            duncan webster 1
              @duncanwebster1
              On narrow gauge locos I’ve worked on they are held on with brass screws. Possibly the only time I’d contemplate using a 12ba screw. 14 ba would be even better, but there are limits. A friend of mine who worked on full size locos reckoned 12ba was a surface finish, not a thread
