A few minutes with a decent CAD program is a great help when visualising exactly whats going on as a tap reaches the bottom of a blind hole. Whether a standard drilled hole or an (almost) true flat bottom created with a slot drill.
Fairly obviously its impossible to tap into the conical end of a drilled hole so some of the theoretical lost depth of thread is accounted for.
Its also essentially impossible to create a true thread with a tap having effectively zero taper, so the starting cut is full depth, without pretty sophisticated guidance to ensure it enters squarely.
The typical 2 or 3 thread taper on the common variety of spiral flute taps is probably the minimum taper for effective starting when hand tapping where guidance can never be as good as an accurately set up machine. It’s important that the screw or bolt is not so long as to enter the tapered portion. Given the impossibility of completely cleaning all the tapping lubricant out of such small holes over-long screws can easily be driven so hard into the short taper that removal in one piece is a fraught, or even impossible, task. I prefer to run a tap ground off dead square down the hole after tapping to remove any taper and reduce the risk of jamming. Its far easier to feel if a screw comes up to the end of the thread.
Naturally we wouldn’t make the mistake of using an over long screw in our work. “Ahem”! But I see a considerable amount of repair and fixing work and need to minimise the chances of getting job back with an even more intractable problem. Extracting sheared 2.5 mm screws is not a favourite pastime. Bridgeports aren’t designed for the weeny centre cutting end mills needed. (Will teh guy with a quill master attachment please stop sniggering!)
Effective lubrication during tapping is problem. I tend to poke some Trefolex down the hole with a thin wire before starting work. Seems to me that anointing the tap is ineffective as its the business end that needs lubrication but any compound on the tip will surely be wiped off after a turn or three.
I’ve seen it suggested that short, slender, sticks could be cast from candlewax or similar and dropped down the hole. As the tap advances it crushes the stick not only producing a continuous supply of lubricant at the tip but also helping to push the swarf up and out. Fully cleaning any residue would seem impossible tho’. It is of course arguable that some lubrication of a teeny thread is desirable debit increasing teh risk of overtigntening and jamming it the screw entered the tapered thread left at the bottom end.
