All, I need to make a small shaft about 55 mm long. It is to fit between two bearing blocks, so the shaft will have a c.12 mm diameter central ‘bulge’, with two 8 mm diameter x c.15 mm long spigots either side to fit into the bearings.
All the cylindrical features need to be coaxial, and also there may be a requirement to turn down the central bulge later depending on experimentation on the device (an equatorial platform for a telescope).
I assume turning between centres is the way to go, starting by cutting the bar to length and centering the ends. I’m struggling with how to grip the small stock firmly for turning, without damage? The turning dog I’ve got is way too big for this job.
Also, I’m turning from 12 mm A/F hex leaded EN1A stock because that’s all I’ve got spare at the moment.
Any advice on quick ways to make an improvised driving dog?
Thanks.
