Paul, are you left handed?
If you compare all the other numbers that are against vertical dimensions you will see that the bottom of the numbers are to the right so that 6mm is actually 9mm.
Good to see someone is making one, If you want to message me with an email address I’ll send you the full size A4 versions, These also contain the title block that he Editor decided to omit so have the scale and material on them.
