EMCO MAXIMAT V10 LATHE
Home Forums General Questions EMCO MAXIMAT V10 LATHE
  • #775426
    MickB
      @mickb25219
      I have just taken delivery of the above but it has suffered some damage in transit. The bracket holding the lead screw to the main lathe body at the tailstock end has sheared in two.
      Any ideas on replacement parts at all?
      Joseph Noci 1
        @josephnoci1
        No spares at EMCO Austria, none at EMCO in South Africa either – unlikely to find as a used part since it would probably be attached to a whole lathe…If you are not averse to joining Groups.io you can try the EMCO V10 group – good folk there – https://groups.io/g/emcoV10lathe/topics.
        ELse just make a new part – it is quite a simple part- from aluminium, you could even get away without the bronze bush if lazy.
        #775496
          If this is the item in question …. it looks like ‘a breakage waiting to happen’
          https://www.ebay.com/itm/267030797579
          MickB
            @mickb25219
            I think that’s a part from the power cross feed version but similar concept
            IMG_0201IMG_0198
            #775508
            bernard towers
              @bernardtowers37738
              As said before quite a simple part or there is silver solder or brazing with manganese bronze rods.
              #775511
              MickB
                @mickb25219
                Bernard
                I think I will try and find a local welder who is capable and prepared to do the job.
                Unfortunately I have no skills whatsoever to make such a thing but am very grateful for your advice .
                MickB
                #775518
                MickB
                  @mickb25219
                  Joseph
                  Many thanks for that link.The first comment on the site has been posted by the chap who sold the lathe to me!!
                  Have to feel for him, I don’t think he could have done much more to wrap and protect the lathe but it still didn’t make it undamaged.
                  I will try locally to see if it is feasible to repair it I think
                  #775541
                  duncan webster 1
                    @duncanwebster1
                    Looks like cast iron, if so then arc welding with nickel rods was used to repair a broken cylinder casting on  narrow gauge railway I worked on. You’d need to find someone who already had a box of rods, they are very expensive.
                    In these modern times I wonder if JBweld would be strong enough. The fractured surfaces should knit back together as CI is very brittle.
                    #775543
                    duncan webster 1
                      @duncanwebster1
                      Google finds loads of specialist cast iron welders, location will be your problem, they probably won’t be bothered with posting, too much messing for a small job
                      #775545
                      Andy Stopford
                        @andystopford50521
                        Since the back is hollow, Duncan’s suggestion of JBWeld, packed into the hollow, seems promising, and it avoids the possible distortion or cracking (a risk with something as thin-walled even with careful pre-heating) from welding.
                        #775547
                        John Haine
                          @johnhaine32865
                          Might it be possible to combine JB Weld with inserting a couple of bolts to reinforce?  Glue first, then drill clearance holes.
                          #775607
                          Graham Meek
                            @grahammeek88282
                            These brackets on Emco Machines tend to be a Mazak (or Similar) die-casting. I know on the Emcomat 7 which I had, which was a forerunner of the V10, and on my Maximat Super 11, which was the V10 successor that this was made of Mazak.
                            Given the thrust exerted on this bracket from the leadscrew a new part made from aluminium would be a much better solution.
                            Gray,
                            #775610
                            Dave Halford
                              @davehalford22513
                              IMG_0201IMG_0198
                              Indeed it is Mick that’s a V10P part with the extra feed shaft hence the two bearing holes.
                              Please check the leadscrew is still straight before you have it welded. Also be aware that the casting is very likely to warp during a hot process. Yours has also cracked around the end corner as well.
                              As a general usage point never ever change those gears when they are moving or teeth will come off, nor try to forcing the gears into mesh. Rock the chuck back and forth till they engage, the forks are made of cast alloy and will break if you try to force the levers.
                              #775613
                              MickB
                                @mickb25219
                                Graham
                                i think you are right. This piece has a number
                                of hairline cracks around it .
                                The seller has kindly agreed to take it back and have a new one manufactured.
                                Many thanks for all your kind responses
                                #775629
                                Graham Meek
                                  @grahammeek88282
                                  Mick,
                                  The fact that it is covered with hairline cracks means the metal is suffering from Hydrogen Embrittlement. A lot of the early diecast materials suffered with this. It was an accident waiting to happen.
                                  Gray,
                                  #775678
                                  ega
                                    @ega
                                    I shall now go and check the corresponding item on my Myford which is now, I guess, quite a bit older than the Emco!
                                    Does hydrogen embrittlement occur through ageing?
                                    #775693
                                      Apologies if I complicated the matter
                                      … I was simply trying to illustrate the weakness of the basic design, which is common to both versions.
                                      MickB
                                        @mickb25219
                                        Michael
                                        Not at all – I very much appreciated your assistance
                                        #775855
                                        duncan webster 1
                                          @duncanwebster1
                                          According to wikepedia, it called zinc pest, and is caused by lead impurity in the metal. Somewhere I’ve read that after about 1950 manufacturers were aware of the problem and got rid of the lead, so later mazak should be OK.
