Sorting and organising hardware.
Home Forums Workshop Techniques Sorting and organising hardware.
  • #769951
    jaCK Hobson
      @jackhobson50760
      I dropped this lot on the floor and entropy took over.
      I might try and organise again… but what is good method for sorting and how should i divide them up – a sensible compromise between perfection and effort?
      Maybe I just split metric vs everything else as a starter?
      I think washers in a separate bucket is sensible.
      Bantam Bill
        @bantambill
        Do what I do and Chuck it all in a big box under the bench, where you then realise that it’s quicker to nip down the shops and buy that elusive bolt rather than search for it in the box. But you can’t get rid of it because your grandfather started the collection during the war.
        #769959
        larry phelan 1
          @larryphelan1
          Dont see anything wrong with that, just a bit mixed up that,s all.
          I have several boxes like that, full of things that will come in “handy” some day, assuming I live long enough, somewhat doubtful at this late stage.
          Should I throw the whole lot out ? No way, I began this collection when I was only a lad and we grew up together. We are now like twins, not sure which is the better looking.
          #769961
          bernard towers
            @bernardtowers37738
            But when you are at work and you go to the stores you just open the right drawer and there it is!. Why dont we do it at home????
            #769968
            Russell Eberhardt
              @russelleberhardt48058
              Not enough drawers!
              Russell
              #769970
              jimmy b
                @jimmyb
                Jack, I feel your pain!
                I’ve got quite a few tubs of assorted fasteners myself and this does happen.
                I also know exactly what you mean about growing up with them. I recognise a fair few fasteners from my past, the domed 6mm cross head (JIS) from my SS50 moped often turns up. Like you I will never throw them away and start again!
                Good luck!
                Jimb
                #769972
                Andrew Tinsley
                  @andrewtinsley63637
                  I sorted all my nuts and bolts out into type and sizes, store them in plastic seal bags and then plastic ice cream tubs. It took a few hours, but its done now and I reap the benefit with quickly finding that the bolt I want isn’t there!
                  Andrew.
                  #769973
                  Harry Wilkes
                    @harrywilkes58467
                    I have 3 of those under my bench, one s that heavy I’ve broken the one end pulling it in and out.
                    H
                    #769976
                    Nick Wheeler
                      @nickwheeler
                      Not enough drawers!
                      Russell
                      More a matter of hoarding festering crap like in the photo.
                      Best way to organise it is to place carefully in the bin.
                      Yes, I have followed this advice with lots of my own junk. No, I’ve never needed any of it since,
                      #769979
                      duncan webster 1
                        @duncanwebster1
                        Even in my home workshop, when I open the right drawer there it is. Problem is all the wrong drawers I open first
                        #769997
                        Nigel Graham 2
                          @nigelgraham2
                          I mounted my ‘Warco’ sheet-metal former on a trolley with four of those umpteen-drawers cabinets nested between bench-top and a floor above the castors.
                          The sort of hard plastic drawers whose very brittle handles easily break off.  The boxes themselves designed to trip the contents up to lodge in the case shelf, preventing opening the drawer.
                          One day I may even finish labelling them by letter-number: A to D for the cases, 1 to n for the drawers in each. Accompanied by a spreadsheet of contents, so allowing the contents of individual drawers being changed over time.
                          Otherwise…..
                          I still spend more time looking for a tool than using it, or discovering the number of a screw of certain size in stock is normally (n-1) where n is the number needed. So buy a new pack of 50 from Toolstation then find the nth some days later in another box of accumulated curios. When looking for something else.
                          #769998
                          Bill Phinn
                            @billphinn90025
                            When I was young, every time my father needed a fastener he used to empty out several large baby milk tins full of screws, washers, nuts et al. on to newspapers on the garage floor and sift through them all until he found something that fitted the bill. It was rarely the ideal fastener for the job, he even more rarely found two the same, and it was far too time-consuming to be any kind of system that could be described as efficient.
                            I reacted against that and sort my fasteners differently, though I have several misc. tubs like Jack’s as well. The picture shows about a quarter of what I’ve got sorted into labelled boxes.
                            IMG_1006
                            #770012
                            Diogenes
                              @diogenes
                              Split it into nuts, washers, bolts, set-screws etc. – I mean you’ll know what class of item you will be wanting when the time comes to look, right?
                              I keep ‘old’/obsolete fasteners & hardware in boxes, buckets etc, and tip ’em into a big tray to inspect the contents – when you find the thing you want just tip it all back in it’s container again – the trick is to have a big enough tray so that everything can be spread out easily..
