Thin thermal work gloves
Home Forums The Tea Room Thin thermal work gloves
  • #769887
    JimmieS
      @jimmies
      Any kind sole have thoughts about thin thermal work gloves for general workshop use – no machining. The nitrile/vinyl/latex versions don’t help keep the finger tips cosy and cotton ones snag too easily. Am I asking for the impossible?
      Peter Cook 6
        @petercook6
        Have you tried the thin polyester work gloves with a rubber grip on the front. Like these
        #769894
          I use these on site when doing rough/dirty work, quite thin but should keep your pinkies a bit warmer too.
          #769897
          Paul Lousick
            @paullousick59116
            Look for mechanics gloves. Thicker and tougher than the normal latex type gloves.
            #769902
            Macolm
              @macolm
              For a comprehensive look at what is available, try http://www.gloves.co.uk/
              #769903
              Sonic Escape
                @sonicescape38234
                Not really a glove, but when working in cold environment I discovered that it helps a lot if you use a hand cream. I’m not sure why. Maybe dry skin is more sensitive to cold.
                I read about this when I was a child in a book where the main hero had to do some repairs in a high flying plane and he rubbed his hands with fat. First time when I got out in winter to have a snowball fight I used my mother’s hand cream and it made a difference.
                #769904
                Martin Kyte
                  @martinkyte99762
                  I would imagine that any kind of grease would prevent evaporation so you wouldn’t get the chilling effect of the latent heat phase change loss.
                  regards Martin
                  #769905
                  Plasma
                    @plasma
                    I use oil grip gloves from the link provided above. They’re not cheap but have very thin leather palms and a fabric back. They really are good for general workshop use.
                    #769923
                    Robert Atkinson 2
                      @robertatkinson2
                      Tip I got from an old fly fisherman:
                      Thin cotton, or even better silk*, gloves with nitrile/vinyl/latex over the top. change over cloves as required.
                      Robert.
                      *He used surplus RAF flying under-gloves that were intended to be worn under leather gloves so maybe the idea is not so new.
                      #769925
                      Vic
                        @vic
                        I bought some top branded work gloves from a specialist supplier some time back. Both pairs were no where near the stated size so I have them to my wife. I now buy gloves from a local discount store as they have a few pair on display to check the size. So many “medium” size gloves are far too tight for comfort whilst others fit fine.
                        #769926
                        Maurice Taylor
                          @mauricetaylor82093
                          Hi,
                          I’m surprised nobody has said do not wear gloves when grinding, drilling ,turning, milling etc.
                          Maurice
                          #769931
                            Op said “Not for machining”
                            #769934
                            Maurice Taylor
                              @mauricetaylor82093
                              Hi,
                              Sorry to repeat what  the original poster said, wasting the forums time.
                              Maurice
                              #770223
                              JimmieS
                                @jimmies
                                Many thanks for advice and suggestions – much appreciated.
                                Jim
                                #770231
                                bernard towers
                                  @bernardtowers37738
                                  Just read the fly fishing post by Robert and I do the same trick for pike fishing
                                  #770528
                                  Trevor Drabble 1
                                    @trevordrabble1
                                      <li style=”text-align: left;”>Further to the information supplied by Macolm in his post of 11/12 , I had never heard of that company , but checked out their web site and eventually I ordered a set of their 295 gloves as most suitable for my purposes. They arrived today , complete with copies of their compliance with a number of standards . As had been said already ,  not cheap, but to me they look and feel worth every penny . Hope this information helps JimmieS in his decision making.
