100g +/- 0.1 mg metrology weight standard?
Home Forums Workshop Tools and Tooling 100g +/- 0.1 mg metrology weight standard?
  • #765183
    Ian P
      @ianp
      This came from a metrology department that closed down and I have wondered what the tolerance number mean in real terms. the plus minus value of 0.1mg seems to infer that this 100 gram weight is +/- one millionth of its value.
      Is that correct?
      Ian P
      Ian PIMG-20241118-WA0007
      Clive Steer
        @clivesteer55943
        Hi Ian
        The item is 100 grams reference mass with a tolerance of 0.1milligrams. How much it weighs will depend on the value of gravity at the place of measurement. If you have two of these and place them on a mass balance, which look like an Apothicary’s scale, they will balance. A force balance, which is the more normal instrument for weighing, only measures the force acting on the mass due to gravity so the instrument will need a known reference mass to calibrate it and this is what these are commonly used for.
        Mass standards can be toleranced to +/- micrograms and are usually made of materials that don’t oxidise and never handled.
        CS
        #765193
        Ian P
          @ianp
          I understand the effect of gravity and the need to use care in handling standard weights that comply to international standards.
          I Googled quite a bit but could not see what class of accuracy this weight fits into.
          Ian P
          Edit, But I dont have the test certificate anyway
          #765230
            Rather strangely … this NPL page refers to 2019 as a time in the future … but, putting that aside, it’s a good ‘rabbit hole’
            https://www.npl.co.uk/mass-mechanical-measurement/mass-standards
            Refhttps://www.npl.co.uk/kibble-balance
