When an industrial process gets in to the hands of the ad fellows and then into the domestic market all sorts of interesting terminology will come into play, often not correct or true. The very term MIG, The I is for inert as in the gas. If using Co2 then this is MAG, A = Active gas, and as no gas in the Gasless version we are left with just M, now it’s getting silly ! Wire welding, that makes sense ! What happens in the molten weld pool is of little consequence to the fellow welding up an old car but if said weld is a critical point where failure has consequences then it is different.
A poor quality and under powered machine for the job, used by an untrained or incompetent person is a very dangerous mix. That the weld may look OK just makes the matter worse ! I was on the receiving end of such a mix, that had potentially fatal results !
Peros mention of feed rollers, there are numerous types, at least in part down to how much you pay, then there is the steadyness or not of the drive motor, ranging from cheap small permag motor to high quality flat motors, add stepped controls – Oh what fun !
Sorry ! None of this helps the OP ! I’m sure there will be good and bad wire, but if you can get it in small reels, don’t know. I would try a smaller wire if available then you will need the right feed rollers. It would be better to just pay up one way or another and do the job properly. Good Luck. Noel.
