NB: MY PC IS COLLAPSING AROUND ME..
So I may vanish like the Cheshire Cat, unexpectedly. Which might relieve the “mouse”…)
It will need professional attention. It had blocked access to one of my most important spreadsheets (before I could back up its latest edition), and now to ‘Word’ and Excel’ generally. It also freezes for the Hell of it.
To business.
As far as we can determine from its documents, my Steam Accumulation Tests on this boiler were the first.
There is NO mention of them on any of its previous, SFMES, certificates. The boiler was made non-commercially in 2000, by a retired commercial builder of miniature boilers, to replace the original steel one that had expired. He was a Society member so built it as a favour to the Society. So we don’t have any manufacturer’s certificates either: it was tested as being “home-made” by a member, though I am sure he would have carefully tested it to at least the standards of the time before it was installed.
So it is possible the boiler testers were more concerned with the ability of the safety-valves to lift at the right pressure, than with maintaining it as the SAT investigates.
The initial suggestions to countersink the inlet ends of the passages, and add more holes to the cap nuts, would be first to try as they do not affect the mechanical behaviour. They simply give a freer flow to the steam.
I have not made any engineering changes that could affect the boiler’s steaming rate – but washing the boiler out and using a particularly good coal might have some bearing on the subject.
The grate and ashpan (which never had a damper) are as fitted in that rebuild; so in theory nothing has changed since the locomotive was last used some eight or ten years ago. Though idle it has spent at least some of those years indoors, snuggled up to a radiator in Winter. (Lucky thing – comfier than its owner…)
Another approach to the blower problem is to limit the control valve opening, e.g. by a spacer on the spindle (if the design allows) or an external stop that acts against the handle. This one has a lever-type handle, not a hand-wheel. These modifications would be simple to make and to change.
As far as I know the two manifold valves do not have captive spindles. (I’ve not tried unscrewing them!) I don’t think retrofitting them, although wise and perhaps policy in some societies, is called for anywhere. It is an advisory not stipulation, but I could verify that from the orange-on-white book; and obviously to consider if I replace these ones anyway. Such a valve can readily be given restrictor-spacers to experiment.
I should add that irrespective of locomotive, it has always been my practice to close the blower a little at a time as pressure rises, and at blowing-off to leave it open only just enough to make the fumes go the right way.
On this loco the blower was effective in my tests last week, from only about 20psi on the gauge!
So essentially. combing advice on here and from my club’s boiler-testers and other engine-owners, first approach is to smooth the flow of steam through the safety-valves without changing the basic design, and some form of choke or opening-restriction on the blower control.
Another problem I have to sort is the reluctant injector, and one suggestion passed on by a fellow club-member, is to fit a larger steam-valve and pipe. The theory being an injector wants plenty of steam, not just “strong steam”. Volume as well as pressure, or more likely, minimising pipe losses. I must admit that’s new to me but there could be something in it.
Regarding a club boiler tester thinking you don’t need a SAT because any decent engine-man would close the blower (and damper if fitted)…
That is all very well and of course he should, but it ignores human fallibility such as the driver distracted.
Let’s just say my own Societies (I am in two) would not countenance that sort of nonsense. An incomplete test and record would be wilful negligence potentially voiding the club’s insurance, as well as by which a host club of an event like a rally, could bar track access to a visiting locomotive.
