Microscope marking objective
Home Forums Clocks and Scientific Instruments Microscope marking objective
  • #760319
    old mart
      @oldmart
      I have just bought a small job lot of microscope related bits on ebay and this unusual objective was amongst them.
      Made by Carl Zeiss of Jena, it is marked OBEKTMARKIERER  PLANOBJEKTIVE TUBUS with an infinity symbol. The tip looks like carbide and is not dead sharp, but has a tiny radius, and it can be offset from central to about 4mm diameter, calibrated in 0.25_IGP3463_IGP3462_IGP3461_IGP3464mm steps. The whole lower part can rotate and has a rest position and cams downward about 0.5mm when turned. A specialised tool for marking metal surfaces with a ring, it is not sharp enough to mark glass without breaking it
      Roderick Jenkins
        @roderickjenkins93242
        Interesting!
        #760344
          VERY nice !
          … I have a Nikon one, but it uses ink and is nowhere near in that league.
          old mart
            @oldmart
            I’ve no idea what I would do with it, the first photo shows a thin red ring showing when the tip is extended for marking.
            #760365
              I have just found its twin listed here:
              https://www.ebay.de/itm/284579952041
              old mart
                @oldmart
                I hardly think it is worth a fraction of 130 euros, the market will be tiny.
                #760408
                peak4
                  @peak4
                  I wonder if it should be sharp, and has been rounded by misuse/wear, or is a blank awaiting sharpening?
                  Here’s an example with a diamond point, intended for marking cover slips on slides, so the observer can find something of interest again later.
                  https://microscope-antiques.com/watsonom.html
                  Bill
                  #760411
                  old mart
                    @oldmart
                    That Watson with the diamond point is spring loaded, the CZ is not, and would be hazardous if a brittle surface was touched. I will have a look at the tip at about 20-50X and report on the exact profile.
