Jason ive dismantled the compound slide firstly and the leadscrew is moving around 0.45mm back and forth in the nut. So less than 1mm but feels like it.
Better to express the backlash in terms of dial graduations, not guestimates. 1mm, if true, means something is seriously wrong. Before rushing to fix this, be aware that rather high-levels of backlash are acceptable in a lathe because the operator can easily compensate for it. Backlash is perhaps best tolerated until the amount of compensation becomes annoying; that’s because adjusting the nut to reduce it wears the nut out.
Judging by the lead-screw photo, my guess is that the nut either needs adjusting, or is worn out and should be replaced. A good photo of the inside of the nut would help decide.
Dell but what is the thread form , minature acme or what?
Dell says the thread is 40tpi Model Engineer and I believe him, though it might seem an odd choice at first. ME is a Whitworth form thread that doesn’t follow the BSW and BSF standards in terms of diameter. Nor does ME have to! In this example, BSW and BSF both apply to nuts and bolts, not lead-screws. It happens that ME standardised 40TPI on several diameters, one of which I guess happens to be a good choice for the Pultra. In theory ACME, being designed to transmit power, is a better choice for lead-screws, but the Pultra is a small precision lathe, not a metal muncher. 40TPI ME is a good compromise I think.
