Cleanup and deburring wheels
Home Forums Beginners questions Cleanup and deburring wheels
  • #758969
    colinb
      @colinb
      What is everyone using? There are so many choices out there!
      I’m just looking firstly to remove paint/rust/crud from e.g. handwheels of old lathe, and then to polish it up to a nice feeling in the hands.
      Grindstone Cowboy
        @grindstonecowboy
        Lidl had some “Scotchbrite” wheels a month or so ago, but I’ve not tried mine yet.
        Rob
        #758985
        bernard towers
          @bernardtowers37738
          I use 3m medium deburring wheels and they are only used for that too b****y expensive!. had scotchbrite wheels in the past but they just fell apart.
          #759003
          noel shelley
            @noelshelley55608
            If using 3Ms so called unitised discs be warmed ! They may look harmless but will remove considerable metal if not used carefully. I used to use them to take brass casting from as cast to the first stage of polishing . Noel.
            #759032
            Nigel Graham 2
              @nigelgraham2
              Degrease the item first.
              Rotary wire-brushes will evict the worst paint and rust. For paint that’s still fully hard, use paints-stripper first but wash it all off before the brushing!
              Citric acid solution is quite a good rust dissolver, as I found on a very rusty tap, but obviously it won’t fill in pits where the iron has gone back to Nature.
              Then ‘Scotchbrite’ or similar, or wire-wool (wear suitable gloves).
              #759037
              Vic
                @vic
                Yeah, my computer does this to me as well! 🤣
                IMG_2218
                #760058
                colinb
                  @colinb
                  Thanks all
