Creworks Chinese Mini Lathe – interesting
Home Forums Manual machine tools Creworks Chinese Mini Lathe – interesting
Viewing 25 posts - 1 through 25 (of 34 total)
  • #758755
    Lee Cooper
      @leecooper46013
      Just posting this for general interest, and interested to hear experiences if anyone else has one.
      I’ve not heard of this brand before, but it’s your instantly recognisable Chinese mini lathe but with a few features I’ve not seen before, in particular- longer bed length, more powerful motor, larger through spindle hole.
      Reviews on this particular version seem fairly decent but looking at other models which are variations from the same seller it’s the typical lottery and fit-and-finish quality you expect from a cheap Chinese lathe.
      https://www.amazon.co.uk/dp/B0BGMXLDZX
      Anyway I thought the specs, which are not something I’ve seen before in this segment made it interesting. Half tempted to take a punt at this price, given Amazon’s excellent support in the eventuality a return for refund is required.
      Apparently one guy had his open and the headstock has a taper bearing at one end and a standard at the other.
      Clive Foster
        @clivefoster55965
        Really stretches the definition of mini-lathe about as far as it can go.
        The big bore makes it a seriously interesting concept but much of the engineering looks somewhat incoherent. What appears to be a standard mini lathe topside “built up in the sand” with a thick block underneath to bring it to centre height really doesn’t look rigid enough. Saddle looks way skinny too for a machine of near SouthBend size.
        Using simple electronic control to deliver enough speed variation from a motor of only 1,100 W seems to guarantee serious shortage of oomph at lower revs.
        Likely to be very frustrating to use in a “boy set to do a mans job” fashion.
        Shame really because the concept is really nice. Most likely let down by attempting to reach an unfeasibly low price point.
        Were I the designer I’d beef up saddle and topside, extend tailstock travel, add a stepper motor for electronic lead screw and cross feed drive and fit a two speed gearbox along with back gear. Not forgetting a four jaw chuck in the box too.
        Then try to sell it for £1,400 or so and be hugely disappointed by how few customers I got!
        #758767
        Lee Cooper
          @leecooper46013
          Thanks Clive.. you’ve made some informed observations there which may just have saved me a disappointing impulse purchase.
          As you say, it is a shame. I would jump at your upgraded model @£1400. Are there really that few of us who would buy something like that?
          I’ve been looking at lathes for a few months and there seems to be a real gap in the market. I’m not fancying the potential pitfalls that come with second hand for someone of my experience, Sherlines look nice and accurate out of the box but I would prefer something bigger; then you have the mini lathes which seem to become as much a project as a ready-to-go tool.. not what I want. A step up from that it seems to jump to silly money with not much in the middle.
          I’ll probably go with a Warco WM240. A bit beefier and the reviews seem decent, plus I get the impression the QC is a bit better despite coming from the same factory as a lot of the other stuff.
          Anyway drop me a line when your product’s out. I’ve got 1400 burning a hole.. 🙂
          #758770
          Clive Foster
            @clivefoster55965
            Lee
            At 70 years of age no chance of me ever putting a product out. But if I did it would be a CNC system that works properly, easily and quickly in the modern world. Think 3D printing style, not G-code!
            Concerning that lathe I do have some relevant experience of the potential issues involved from that sort of enlargement.
            Way back I traded up my second SouthBend 9″ lathe, a model A, for a late SouthBend Heavy 10 toolroom version with big bore spindle and cam lock chuck fittings. For all practical purposes the Heavy 10 simply increased the swing by 1″ with a bigger bore and beefed up headstock but everything else was pretty much the same size as the 9″. Excellent on lighter work but just not strong enough to handle the cuts needed on bigger jobs.
            Frustrating.
            The lathe you linked to has even more enlargement relative to the basic source design size so the issues will be compounded.
            The Heavy 10 got swopped for a Smart & Brown 1024 which is pretty much a cut down bigger lathe retaining the massive saddle, topside et al. Saddle and slides are actually bigger than on my P&W Model B 12″ x 30″ which itself is actually almost 14″ swing and has a well earned reputation for both accuracy and the ability to take heavy cuts.
            Having way too much strength in saddle and slides is liberating.
            #758789
            bernard towers
              @bernardtowers37738
              How can that be a mini lathe with those dimensions?
              #758798
              jimmy b
                @jimmyb
                I think my SC4 lathe has the same bearing arrangement. Not given me any cause for concern
                jimb
                #758812
                old mart
                  @oldmart
                  It has potential to be good, probably after some fine tuning has been carried out. One drawback with many of these lathes is the way the swing is increased by raising up everything rather than making a stouter lathe. The bed looks hardly heavier cross section than the 7 x 12 that I have. A nice strong bed for a mini lathe, but somewhat flimsy without being scaled up in size.
                  #758836
                  Lee Cooper
                    @leecooper46013
                    Put me on the waiting list for one of your CNC’s too, Clive.. but I jest. It does sound like a great concept though!
                    Interesting to hear some insight from you on how you developed your perspective on the inadequacies of the lathe I posted. Quite frankly none of this occurred to me.. you live and learn.
                    #758837
                    Lee Cooper
                      @leecooper46013
                      jimb
                      Thanks for the heads-up, Jim. I suspect most mini lathes are just plain bearings all round and the bearings do not appear to be one of the primary pain points on these types of machine.
                      #758838
                      old mart
                        @oldmart
                        I would think that the head bearings would be the best part of the lathe, definitely not plain type.
                        #758842
                          On Lee Cooper Said:
                          … I’m not fancying the potential pitfalls that come with second hand for someone of my experience, Sherlines look nice and accurate out of the box but I would prefer something bigger; then you have the mini lathes which seem to become as much a project as a ready-to-go tool.. not what I want. A … I’ve got 1400 burning a hole.. 🙂
                          Bear in mind much of the criticism of Far Eastern kit is ancient!   And there are people who can’t cope with the idea that foreign hobby machines are worth owning!  They delight in spreading FUD.
                          Been a long time since machines arrived covered in ‘Chicken Fat’ anti-corrosion grease.  And they all have better control electronics now.   They’re functional rather than well-finished.  Due to internet misinformation, I expected my mini-lathe to arrive as a ‘kit of parts’.  It didn’t.   Worked out of the box.   It did benefit from some minor fettling, such as increasing the depth of the hole the high-low lever detents into, but nothing major.
                          Later I replaced it, too small, with a WM280 which also worked out of the box.  Only tweak necessary was to one of the dials, which contained a poorly finished leaf spring.  My WM18 mill required no work at all.
                          All have good accuracy.. What’s missing is a smooth feel and the ability to blast through hard-work on a 3-shift system.  Hobby machimes are less tolerant of heavy-handed unskilled operators!  Otherwise they perform well-enough.
                          My band-saw was less satisfactory.  It also worked, but didn’t cut straight, clicked, and the gearbox cover very slightly oozed oil.  This one required more fettling, but nothing difficult.   The too cheap Carbon Steel blade it came with was half the problem.  But I did have to do some filing and replace a gasket.
                          £1400 isn’t much money for a machine tool.  Multiply your budget by 10 to 20 for a new industrial grade lathe! It will be better than you need.  And the forum isn’t full of members complaining about their faulty WM240s!
                            Wouldn’t touch it with a 10 foot pole. As said above the vertical stretch on standard narrow bed is not going to work well.
                            Have a look at the Sieg SC4 at 1200 Quid from Arc Eurotrade. A much more solid and usable machine with good after sales back up.
                            Amazon returns policy is not going to cover a machine that works but works poorly due to inherent design weaknesses. Caveat emptor.
                            #758926
                            Ian Hewson
                              @ianhewson99641
                              X1 for the sc4.
                              Ian
                              #759058
                                Also, don’t forget to check the motor OUTPUT.  That 1.1kW very likely refers to power input, so the output may be only half that!  Chinese units are often hyped to appear as high as possibly possible and worded to appear impressive to anyone that is scammed by them.
                                #759060
                                  Bit like their 2.5hp air compressors. Leave off the 2 would be closer to the truth.
                                  #759065
                                  Lee Cooper
                                    @leecooper46013
                                    Good point RE input vs output power guys- noted.
                                    Just checked out the Sieg SC4 as per recommendations, it’s now over 1500 notes.
                                    #759070
                                      You might be better off with the SC3 minilathe at 900 Quid then. Or if you absolutely need a bigger machine, a used Myford ML7 or Boxford or Raglan. Plenty around in good condition with little use in home workshops if you shop around.
                                      #759091
                                      Clive Foster
                                        @clivefoster55965
                                        Don’t knock plan bearings. The old SouthBend 9″ lathes which had simple but deceptively sophisticated plain bearings bored directly in the headstock were renowned for long life and accuracy. My first one had no detectable headstock wear despite having done enough work to wear the feed drive key down not about 1/4 of its original width. The Heavy 10 with its shim adjusted bronze bushes was no slouch either when its came to strength, accuracy and long life. Then there were the high speed plain bearing Holbrook C machines built for diamond turning and similar super precision jobs. When the objective is optical surface finish you need the best bearings that can be had.
                                        In our home shop world the issue has always been affordability. High quality plain bearings are relatively complicated and expensive to make, consider the many taper style adjustment systems used on the machines we couldn’t dream of affording new, so once decent roller bearings could be gotten off the shelf thats the obvious way to go. Lubrication is an issue too. For best results at any sort of surface speed plain bearings need proper pump fed lubrication supplying decent clean oil. On bigger machines the eye watering cost of sophisticated, matched assembly Gamet and similar high end roller bearings was still considered cheaper and more reliable than trying to do super precision plain ones on the assembly line.
                                        These days the tier 1 automotive suppliers make plain bearings of more than adequate quality and life for very low prices. But you need the pump and filter to use them.
                                        My big criticism of our Asian suppliers is that the machines they deliver are conceptually way out of date. They haven’t moved on from the original “leverage the supply chain to make SouthBend, Myford, Boxford, Bantam style machines cheaper”. Nice in many ways but classic design for sales rather than proper machine tool engineering development and not going anywhere. Doomed to extinction in a world with carbide inserts, 3D CAD and 3D printing. But thats a story for another thread.
                                        #759165
                                          Exactly.  They quote displacement not free air delivery (FAD).  Only the latter is a reliable way to choose one.  Compressors were always quoted FAD until the chinese realised they could con the buyers by issuing higher numbers for less money.
                                          Same with chinese heaters – cheap 8kW diesel air heaters do not exist and even the touted 5kW versions likely deliver only a tad ove 4kW.  And so it goes on….dupe the ‘less well informed’ buyers.
                                          #759412
                                          Lee Cooper
                                            @leecooper46013
                                            Well I don’t *think* it classes as a mini lathe but after much deliberation I’ve decided to go with a Warco WM180. If it’s not everything I hoped for I rest safe in the knowledge that I can bitch to SillyOldDuffer about it.. 🙂
                                            Can’t wait to get into the game and ‘be one of the boys’ so-to-speak.
                                            #759422
                                            Diogenes
                                              @diogenes
                                              On not done it yet said:
                                              … ..Compressors were always quoted FAD until the chinese realised they could con the buyers by issuing higher numbers for less money.
                                              Sorry NDIY, but that’s just nonsense – reputable industrial suppliers have always quoted FAD, but ‘domestic’ / ‘hobby’ outlets such as DIY store chains and ‘Discount Tool Warehouses’  quoted displacement figures for compressors and input figures for power machinery for as long as I can remember..
                                              IIRC things were so bad by the early 1980’s that there was an ‘air’ company (from, maybe ?Sheffield?) who were able to use ‘full disclosure’ of spec for home-gamers as a Unique Selling Point, closely followed of course by Axminster, who really promoted their ‘transparency’ as a marketing tool that proved hugely successful – both of these companies sold imported machinery.
                                              Why perpetuate conspiracy theory couched in such such offensively racist terms?
                                              #759430
                                                Nothing racist about pointing out poor quality or otherwise of goods manufactured in a specific country. Nothing to do with the race of the people working in or running the factories.
                                                In many cases in the hobby market, it is the local (non-Chinese) importer/distributor who tells the factory what to make, or chooses which quality-level of product they want to slap their badge on.
                                                But there are well documented problems with quality control in Chinese factories. Whole books have been written on the problem, which has come to be known widely as “quality fade”. ( LINK ) (Scroll down to read the summary)
                                                It is not down to a matter of race, but rather of Chinese Communist party politics where corruption is endemic and huge pressures are put on factories to meet quotas and produce short-term profits. Nobody knows if they will be in business next year because the latest political purge may have removed their party mentor who is vital to getting party permission to run a business or factory. So they are focussed on making money while they are able to and the future be damned.
                                                Meanwhile, the Chinese machine tool manufacturers in democratic Taiwan are recognised as among the world’s best. Their lathes and mills sell for ten times what the mainland Communist Chinese machines cost.
                                                #759434
                                                  Congrats on your new machine. Enjoy!
                                                  Yes I think at 7″ x 12″ (180 x 300) the WM18 would be classed as a minilathe. Unless there are more subtle differences the afficionados get testy about?
                                                  #759471
                                                    Maybe those reputable importers did a good job in being transparent, but for “as long as I can remember”, which may be less in this field, it has been the cheap chinese imports that were hyped.  My ‘old iron’ compound compressor was bought second hand from a farm sale about 30 years ago and is still going fine.  A genuine cast iron twin cylinder (compound) pump with 3HP motor, <u>delivering</u> around 10cfm.
                                                    The chinese can make very good products, but the cheap end (often aimed at hobbyists) leaves a lot to be desired where complete truthfulness of the product is concerned.  They pay (in one way or another) for good reviews.  They exaggerate the capabilities.  They provide misleading data (eg motor output power) – Arceuro do provide power output values, but I expect some outlets don’t do this for Sieg machines.
                                                    I have cheap chinese diesel heaters.  8kW versions simply cannot exist but are advertised as such (the pumps are insufficient and the fan speeds are already at maximum, even for the claimed 5kW versions).
                                                    Cheap chinese bearings were ‘outed’ by John (doubleboost) in one of his earlier videos (headed ‘chinese shite’ IIRCC).
                                                    I have cheap (imported from China) dehumidifiers.  They are rubbish for durability.  ‘Chicken fat” lubricants was the most common issue, leading to failed drives or fans.
                                                    I once bought a MT2 adapter which was not quite MT2.   Ban good carp.
                                                    I recently bought one battery cell balancer.  It did not work.  I needed 7, so I will try a better supplier – not directly from China!
                                                    Bangood, Vevor and Temu, among others, are a lottery where quality and specification adherence is concerned.
                                                    I avoid cheap chinese, unless I am able to fix it or can accept the shortfalls.
                                                    Good quality costs.  I remember one place I worked sent two containers back to China because the contents failed the quality required and the QA checks before being accepted.  Every consignment, <u>afterwards</u>, exceeded the quality inspections on arrival.  The Chinese supplier clearly could supply good quality but tried, initially, to get away with sub-standard products.  These were mostly electronic parts for electricity meters, BTW.
                                                    I’ve had a lot of experience with chinese products and (mostly) know how to decide on whether to purchase or not.  One reason why I have purchased most of my hobby items from Arceutotrade.  Don’t even go to Indian quality, either.  I know a bit about some of their (dangerous) practices in the past.
                                                    #759513
                                                    Andy Stopford
                                                      @andystopford50521
                                                      To my mind, “Minilathe” applies to a particular design (reputedly originally of E.European/Russian design), of which the “Creworks” is a stretched version. Warco’s standard length version is here:
                                                      https://www.warco.co.uk/metal-lathes/303410-mini-lathe.html
                                                      The WM180 is quite different and appears to be based on the Emco Compact 8:
                                                      https://www.lathes.co.uk/emcocompact8/
                                                      Having used both, I’d say the WM180 is much more rigid and behaves much more like a ‘proper’ lathe. Like its Emco ancestor, it lack a tumble reverse to the leadscrew, and has a slightly odd single slot banjo for the change gears which makes it difficult to cut anything other than the standard (but wide) range of threads advertised (it’s quite clever how they managed to get the range that they do out of it). I have thoughts of an electronic leadscrew for mine.
