The slightly larger flat four “PEEWIT” and the opposed twin derived from it that was in ModEngWorld are not the same engine as Emgee is after. I do have the issues of SIC that the PEEWIT was in.
I suppose at 5.3cc it uses some of the V8 parts as that was 10.6cc
Complete volumes available on ebay or from Tee publishing but a bit pricy.
Thanks for the link to the great pictures, yes it is clear from those the common parts are the cylinders, pistons and rods. the cylinder heads are also the same design but for 2 and not 4 cylinders.
John, a twin only has two cylinders. It’s a 5.3cc flat four “boxer” engine we are after.
There is also an earlier mention of a “Flat Four 4-stroke” but whether that is the one Emgee wants or the Peewit I am not sure. Only a single issue of Mod Eng World also seems a bit short for a full set of plans, maybe just an article about one of his flat fours?
Many thanks to all who have responded to my request, knowing now the engine is described in SIC magazine I will check my index of copies for the article.
