I cannot see what you thought rubber mounts would help with unless you intended to run the machines while moving down a farm track.
What you might consider is putting each machine either at the feet or the bed on some kind of frame that provides only 3 point mounting to avoid any flexing of the trailer being transferred to the machine which could in extremis, crack the cast iron. Interested to hear if the army workshops take this approach.
Containers are very expensive to have moved, can be 50% of the purchase cost.
