Drill hard cast iron 1.7mm 10ba clearance
Home Forums Hints And Tips for model engineers Drill hard cast iron 1.7mm 10ba clearance
  • #749354
    Peter Venn
      @petervenn53369
      I have a casting of the Chimney on my Adams O2 which I’m building and it is fully machines and ready to mount on the smoke box. However I have found it impossible to drill the base of the casting to accept 10 BA bolts to hold it on. ordinary HSS bits don’t touch it and I ordered some cobalt 1.5 mm and 2 mm drillbits but they don’t seem to want to touch it either!!
      Does anybody have any suggestions about how to soften the casting enough to get a drillbit through it?
      bernard towers
        @bernardtowers37738
        Put it in your BBQ
        #749369
          Fire or BBQ, get it to red heat and hold for an hour or two and then let it cool SLOWLY in the ashes overnight.
          #749415
          John Haine
            @johnhaine32865
            If it’s that hard I wonder how it was machined?
            #749428
            Andrew Johnston
              @andrewjohnston13878
              Use a carbide drill.
              #749435
              Baz
                @baz89810
                I agree with Andrew, use a carbide drill but belt and braces job, give it a good cooking in the BBQ as well. If it doesn’t work you will need to find someone with a spark eroder.
